• 01.10.2026, 22:42
II ARROWS
Monday, January 28th 2019, 10:24pm
Well, I guess so... It should work, theoretically.
eaonflux
Wednesday, January 30th 2019, 9:33am
It works for me... No issue whatsoever.
I also have a splitter for the USB header ( https://www.moddiy.com/products/10%252dP…able-(5cm).html ).
Aquaero 6.
ah thanks i wil order it and try it.
1 split for the aquaero and the other chained to the hubby7 i guess?
mditsch
Wednesday, January 30th 2019, 12:37pm
sorry to ask, but how should this work for the phyics behind? Asking, because here will two devices change signals at one connection?
Aquaero 6.
This post has been edited 2 times, last edit by "mditsch" (Jan 30th 2019, 12:39pm)
II ARROWS
Thursday, January 31st 2019, 9:37pm
USB - S is for "serial".
It's already like that,otherwise you could connect only one device per header. Forget any kind of hub.
mditsch
Friday, February 1st 2019, 6:54am
yes, Serial and not parallel and when you're using a splitter cable you're using it in parallel...
Why do we stupid people than use always electronical USB hubs instead simple splitter cables?
When you have two headers are these headers always two from each other independent electronical USB channels.
Ok, it seems I'm wrong because you're saying it is always working. Please light my fire and describe the technical theory why it is working. I'm always interested in learning new things.
This post has been edited 3 times, last edit by "mditsch" (Feb 1st 2019, 6:34pm)
II ARROWS
Friday, January 21st 2022, 1:35am
Reading it now... I don't know if you are still interested, but in practice the protocol negotiate multiple devices from the same header. Here you can find it how it works in short:
https://electronics.stackexchange.com/qu…llisions/356728
USB - B is a bus: it means multiple devices are on the same lane ready to communicate. Like on the road, a single bus visits all the stops.
Of course having multiple devices means reduced performance, but it's not really a problem for this device.
Similar threads
