• 10.10.2026, 17:51
japemo
Corsair hydro 100i rgb platinum connected/control led by aquaero & aquasuite
Tuesday, April 16th 2019, 3:29pm
Hi friends!!!
I would know if is posible connect an AIO Corsair Hydro 100i rgb platinum to Aquaero 6 LT and controlled by Aquasuite
Thanks for your help!! :thumbup:
This post has been edited 1 times, last edit by "japemo" (Apr 16th 2019, 7:47pm)
Hufeisen
Tuesday, April 16th 2019, 5:55pm
The Aquaero 6 LT can not control LEDs.
To control the Fan LED with Aquasuite, you need a Quadro or a Farbwerk 360. And you need a RGBpx Splitty4.
Controlling the CPU Cooler RGB with Aquasuite is not possible.
This post has been edited 1 times, last edit by "Hufeisen" (Apr 16th 2019, 6:00pm)
GTXJackBauer
Tuesday, April 16th 2019, 6:55pm
Not just any fans. I think it's particular Corsair and NZXT fan's RGB that can be controlled only on the QUADRO.
japemo
Tuesday, April 16th 2019, 8:26pm
Sorry my smartphone corrected controlled by control led...
I want controlled pump and fans with aquaero and RGB led with Farbwerk...
GTXJackBauer
Tuesday, April 16th 2019, 11:11pm
If by Farbwerk 360, yes you can with specific fans.
Check here for more info on that.
japemo
Tuesday, April 16th 2019, 11:15pm
Ok thanx!!!!
GTXJackBauer
Wednesday, April 17th 2019, 2:59am
Ok thanx!!!!
Sorry for the confusion, I meant this one but the other one is a good read too regardless.
Hufeisen
Wednesday, April 17th 2019, 8:06pm
The Corsair hydro H100i RGB Platinum ships with Corsair ML or LL Fans, which are compatible with a Farbwerk 360.
A Splitty4 is required to connect the Fan RGB cable to the Farbwerk 360.
You can control the Fan speed with an Aquaero.
The Pump can not be controlled with Aquaero or Aquasuite software, because the pump only has an USB Connector.
Any setting for the pump (RGB and Speed) require the proprietary Corsair iCue software.
This post has been edited 4 times, last edit by "Hufeisen" (Apr 17th 2019, 8:42pm)
japemo
Friday, April 26th 2019, 12:56am
Sorry but H100i RGB Platinum have CPU_FAN connector, copy/paste from Start Guide:
• Connect pump power cable to an available SATA power plug (figure 1).
• Connect pump tach cable to the CPU_FAN header on your motherboard (figure 1).
• Connect each fan to the shrouded 4 pin connectors on the pump (figure 2).
You can read in H100i H115i RGB Platinum Quick Start Guide
Hufeisen
Friday, April 26th 2019, 6:40pm
This is only a pump tach cable. This cable sends the pump speed RPM to a FAN Header. You can not control the pump with this cable.
This post has been edited 1 times, last edit by "Hufeisen" (Apr 26th 2019, 6:49pm)
japemo
Friday, April 26th 2019, 7:19pm
Yes, sorry.
Alfinal will buy a DDC bomb and Corsair ML140PRO RGB fans and will control them all with Aquaero 6 LT, passive heat sink for aquaero 6 black , Farbwerk 360 and a RGBpx Splitty4.
It scares me that there are people who can not control the RGB of ML120PRO RGB as discussed here.
Regards!!!!
