• 01.11.2026, 17:19
knacker
D5 next- compatible on Corsair XD5 res
Saturday, September 21st 2019, 7:52pm
Can anyone tell me if the D5 next wold connect ok with the Corsair XD5 pump/res combo as client wants to use one with her AE6 but the standard pump doesnt play well with aquasuite
thx
Hufeisen
Monday, September 23rd 2019, 1:57pm
The reason is that the standard D5 pump PWM Signal does not comply with the Aquaero PWM Specifications.
To fix this, you need to modify the Pump Connector and add some resistors.
Read this post how to do it: https://www.overclock.net/forum/61-water…ml#post22946282
knacker
Monday, September 23rd 2019, 3:30pm
that's true- thanks for that but not the question I was asking. :D
Edit: should have asked if the D5 next is a standard size D5 pump :D
This post has been edited 1 times, last edit by "knacker" (Sep 23rd 2019, 4:32pm)
Hufeisen
Monday, September 23rd 2019, 11:01pm
Yes, the D5 next is a standard size D5 pump.
The problem can be the plugable electronic unit with the display.
I dont know if the display of the D5 next will collide with the reservoir or not.
This post has been edited 3 times, last edit by "Hufeisen" (Sep 24th 2019, 12:16am)
knacker
Tuesday, September 24th 2019, 9:34am
thanks Hufeisen
thats the answer I was looking for- just need to check on the depth of the pump to see if the connection will clear the fittings
