• 13.10.2026, 01:08
knacker
Corsair RGB fans/blocks via Farbwerk?
Sunday, October 13th 2019, 11:32am
Is is possible to connect and control Corsiar RGB via a farbwerk- if so what would I need
If not possible, what rgb fans would work with a Farbwerk- 120mm
thx
This post has been edited 1 times, last edit by "knacker" (Oct 14th 2019, 4:14pm)
Hufeisen
Monday, October 14th 2019, 5:37pm
There is not enough Information to answer this Question.
Corsair has a lot of different RGB Fans. What Fan Model do you have? How many Fans do you want to control?
This post has been edited 1 times, last edit by "Hufeisen" (Oct 14th 2019, 5:40pm)
knacker
Monday, October 14th 2019, 5:51pm
6 x LL fans 1x GPU block, 1x CPU block currently on a lightning node pro
This post has been edited 1 times, last edit by "knacker" (Oct 14th 2019, 5:54pm)
Hufeisen
Monday, October 14th 2019, 5:57pm
For 6x Corsair LL Fans, you need:
2x Splitty4
Farbwerk 360
knacker
Monday, October 14th 2019, 6:06pm
2x Splitty4
Farbwerk 360
You sir are magnificent- means I can use the AE fully for everything as the GPU/CPU daisy chain- will get a 3rd spliity just in case
Superb 8) :D
This post has been edited 1 times, last edit by "knacker" (Oct 14th 2019, 6:16pm)
knacker
Wednesday, October 30th 2019, 6:38pm
My order has now arrived and I will be building this soon. Is there a guide on how to connect correctly so everything works
