• 25.11.2026, 23:03
XSkilly
Control another brand pump with a quadro/octo ?
Wednesday, April 8th 2020, 1:01am
Hello !
I'm sorry for my bad english .. I'm french :P
I just mounted 1 week ago my first custom watercooling and i have chosen an Octo from aquacomputeur to monitoring my 6 fans (2 radiator with 3 fan each). I still have 2 fan header on the octo.
My pump is an "ek waterblock xres 140 revo d5 rgb" who's connected to my motherboard with pwm on pump header (Fan-opt)
Simple question can i just connect my pump pwm cable on a fan header of the OCTO ? It is ok to control the pump like if it was a fan ? (i'm suppose my motherboard already do it that way but i'm not 100% sure)
I see that the OCTO can manage 25W output for each fan ? My pump is a 23w max pump. So it's safe ?
(by the aquasuite is just awesome !)Thanks in advance ! :D
hugemon
Wednesday, April 8th 2020, 6:28am
Ek D5 pumps get power from separate 4PIN IDE connector, so you don't have to worry about the output power of the fan controller as long as it's PWM controller.
I have 1 Aquaero and 3+ Quadros and they all control pumps from various manufacturers just fine.
XSkilly
Wednesday, April 8th 2020, 1:49pm
Ok thanks you for your response :D
I'm gonna plug this pwm pump connector on my octo
phuzz
Thursday, April 30th 2020, 6:03pm
I'm probably a bit late to this, but I'm controlling a EK-XTOP Revo D5 just fine with my Quadro and it works great.
