• 14.11.2026, 17:31
RGBpx PicoBlade cable PSA
Thursday, July 30th 2020, 4:53pm
I erroneously assumed (yes, that error) the aquacomputer RGBpx PicoBlade cable pin-out followed the Molex PicoBlade off-the-shelf cable assemblies.
They do NOT!
The aquacomputer RGBpx connectors are inverted, the Molex are not. PicoBlade_Cable.jpg
It would have been nice to have additional cable options, but not to be.
k2viper
Thursday, July 30th 2020, 4:56pm
AQ RGBpx cables are JST 1,25mm 4-pin connectors available via aliexpress and wide range of DIY electronics stores.
k2viper has attached the following file:
This post has been edited 1 times, last edit by "k2viper" (Jul 30th 2020, 4:59pm)
Thursday, July 30th 2020, 6:14pm
I made the post so others would not fall to the same folly as did I.
Due to a slight case of hand tremors, self crimping would not be for me, but I could easily build a cable with 2 housings and 4 same length pre-crimped leads from the selection offered. Just be sure to get the pin-out correct.
Similar threads
