• 14.11.2026, 13:56
tomfassnidge
Quadro alarm state
Saturday, September 5th 2020, 12:31pm
My quadro's fan channel 3 has been in an alarm state since I accidentally plugged in a ddc PWM connector which was wired incorrectly.
The message on the fan page states "Alarm: short circuit, fan output deactivated" - is there a way to deactivate this alarm?
There is nothing currently plugged into that channel - I've tried plugging in other (correctly wired) 4-pin connectors to clear the alarm to no avail.
Have I damaged something?
Thanks
Saturday, September 5th 2020, 3:31pm
i think your fan output is defect.
tomfassnidge
Sunday, September 6th 2020, 11:10am
Ok.
It was working fine before - I had a fan running from it.
There's no way to try to "reset" the alarm state?
tomfassnidge
Monday, September 7th 2020, 8:37pm
Just to update that the issue seems to have cleared itself - turned my pc on this evening and no alarm state.
I don't recall doing anything that would have done this - certainly not intentionally.
Tuesday, September 8th 2020, 2:10am
The snippet below is from the aquaero manual. Perhaps the protection circuitry for the quadro is similar, and having powered your computer down allowed the amplifier to reset.
Quoted
aquaero 6: Maximum current is 2.5 A per output independent of output voltage, resulting in a maximum power of 30 W at 12 V. Outputs will be switched off if amplifier temperatures reach a critical level and will automatically be reactivated when cooled down. If an output current of 3 A is exceeded, the output will be permanently disabled. To reactivate the output, the aquaero (or the complete PC) has to be disconnected from power for a short period of time. The fan outputs are short-circuit proof.
tomfassnidge
Tuesday, September 8th 2020, 5:54pm
I suspect that's exactly what happened.
