• 14.11.2026, 21:00
Kirer
Aquasuit notification - Switch profile not work with OCTO
Friday, October 23rd 2020, 3:03pm
Hello everybody,
For many months I have an OCTO inside my pc, and I am very happy, but from aquasuit x24 I found the following problem:
By setting in the "notifications" section, the change of profile to an event, the profile changes on Aquasuite but not on OCTO.
The general profiles are set up to change the OCTO profiles too, in fact if I change profiles manually or use the automatic function in the "Profiles" section, everything works correctly.
can someone give me some advice ??
PS: the other functions in the "notifications" section work correctly
rays2c
Friday, October 23rd 2020, 11:10pm
Im having a similar issue here.
The profiles on the octo / farbwerk were working. But then after the update yesterday, for some reason, it has deleted all 4 of my profiles and now longer saves any profiles.
Further, the icon in the taskbar to switch profiles dont work anymore either.
In the global profiles under the playground tab in the aquasuite software, the profiles dont save anymore either.
It seems that the update completely broke the profiles in the aquasuite software.
