• 15.11.2026, 02:32
Asryan
Fans splitter on quadro?
Friday, November 27th 2020, 7:10pm
Hi on my QUADRO I have
1x140 plugued
My cpu pump
3x140 with a splitter
3x120 with a splitter
Is it somehow an issue to put some splitters on a hub like this or is it designed for it?
Thanks
k2viper
Friday, November 27th 2020, 8:15pm
Fan splitters should be no issues. To correctly read connected fans rpm, an RPM pin to Quadro should have been wired only from one fan of connected to splitter.
Most splitters have a mark "with speed signal" or "CPU" to the connector with wired rpm.
Asryan
Friday, November 27th 2020, 8:47pm
Great thanks I was afraid it could be too much for one header
Hufeisen
Friday, November 27th 2020, 8:59pm
The maximum Power for each Fan Port is 12 Volt, 2 Ampere or 24 Watts.
The Quadro has Overcurrent Protection, it will disable the Fan Port if too much Power is used.
Bartdude
Monday, November 30th 2020, 10:21am
If you check the fan specs you can work out how many fans will safely work on each header, I personally used Splitty9's as I found it easier running the cables and tidier although more costly than normal splitter cables. I have a large tower though (Corsair 900D) so... :whistling:
This post has been edited 1 times, last edit by "Bartdude" (Nov 30th 2020, 10:23am)
Similar threads
