• 25.11.2026, 04:15
aquasuite changelog - English
Thursday, January 14th 2021, 8:25am
Changelog
aquasuite X.83 (02-SEP-2025)
  • Update: Hardware monitoring
  • Update: Playground: connections
  • Update: After exiting maintenance mode, all output actions are ignored for 60 seconds
  • Bugfix: Device reconnect behavior
  • Bugfix: CSV log data export
  • Bugfix: Service helper
  • Bugfix: RGBpx settings
LEAKSHIELD Firmware 1022:
  • Bugfix: Alarm actions
  • Update: Pump speed increased ( reduced pumping times)
aquasuite X.82 (15-JAN-2025)
  • Bugfix: Hardware monitoring, AMD CPU clock
aquasuite X.81 (6-JAN-2025)
  • Update: Performance and stability
  • Update: Windows 11 adjustments
  • Bugfix: Playground, interval timer
  • Bugfix: Playground, aquasuite user interface
  • Bugfix: Texts and descriptions
  • Bugfix: Reorder of overview pages
aquasuite X.80 (16-SEP-2024)
  • Update: Overview pages, new XAML editor for user-defined elements
  • Update: Playground, new unitless data type that is not rounded
aquasuite X.79 (25-APR-2024)
  • Update: Playground inputs renamed to input values
  • Bugfix: LEAKSHIELD settings
  • Bugfix: Playground texts and descriptions
  • Bugfix: VISION, display output
aquasuite X.78 (13-FEB-2024)
  • NEW: .NET 8 runtime
  • Update: Data logger settings
  • Update: XML, Json, CSV data export, new ID to identify the data source
  • Bugfix: Playground settings
  • Bugfix: Curve controller
  • Bugfix: Screenshot format
  • Bugfix: OCTO overview page
QUADRO Firmware 1033:
OCTO Firmware 1020:
farbwerk 360 Firmware 1025:
farbwerk nano Firmware 1025:
farbwerk Firmware 1010:
LEAKSHIELD Firmware 1021:
high flow NEXT Firmware 1017:
VISION Firmware 1018:
VISION RGBpx Firmware 1010:
D5 NEXT Firmware 1025:
  • Bugfix: aquasuite settings are sometimes ignored by the device
  • Bugfix: Calibration value for the flow output at the signal output has been adjusted
aquasuite X.77 (20-DEC-2023)
  • Update: HWiNFO64 UTF8 support
  • Bugfix: Audio trigger settings
  • Bugfix: LEAKSHIELD dialogs
  • Bugfix: LEAKSHIELD membrane test
  • Bugfix: Playground profile actions
aquasuite X.76 (24-OCT-2023)
  • Bugfix: Settings dialog
  • Bugfix: Playground profil selector
  • Bugfix: Text input with Hungarian keyboard layout
  • Bugfix: Crash when network connectivity is changed
aquasuite X.75 (13-SEPT-2023)
  • Bugfix: aquaero settings
aquasuite X.74 (4-SEPT-2023)
  • Bugfix: mps and poweradjust settings
  • Bugfix: aquaero 5 firmware update
aquasuite X.73 (30-AUG-2023)
  • New: Playground inputs; a range of values can be endlessly processed with one button
  • Update: Playground inputs; button response time when used at overview pages
  • Bugfix: performance and stability optimizations
LEAKSHIELD Firmware 1020:
  • Bugfix: pressure measurement
aquasuite X.72 (15-AUG-2023)
  • Bugfix: Service CPU load
  • Bugfix: Service memory leak
aquasuite X.71 (14-AUG-2023)
  • Bugfix: CPU and memory load
  • Bugfix: Minor bugfixes and Windows 11 adjustments
aquasuite X.70 (10-AUG-2023)
  • Update: Design
  • Bugfix: VISION settings
aquasuite X.69 (29-JUN-2023)
  • Bugfix: Windows 11 USB device detection
  • Bugfix: Search function in data quick view
aquasuite X.68 (02-MAY-2023)
  • Bugfix: LEAKSHIELD diagnostics
  • Bugfix: Tray icon at light theme
  • Bugfix: aquasuite and background service
  • Update: Twitter functionality has been disabled due to new API restrictions
aquasuite X.67 (08-MAR-2023)
  • Update: Calibration values for all flow sensors
  • Bugfix: Text inputs
  • Bugfix: Log data exports
  • Bugfix: Overview pages
  • Bugfix: Profile handing in devices
  • Bugfix: Service
NET 7 installer: https://dotnet.microsoft.com/en-us/downl…s-x64-installer
aquasuite X.66 (Insider) (19-JAN-2023)
  • New: LEAKSHIELD, Membrane Diagnostics Wizard
  • Update: Hardware Monitoring
  • Bugfix: Background service
Fimware updates are included in this version.
After updating the firmware, it is no longer possible to switch back to an older version of the aquasuite.
We ask for bug reports and feedback on X.65 and the following Insider versions. Please use this topic:
aquasuite X (Insider) Version, Feedback, Fehler und Problemlösungen
LEAKSHIELD Firmware 1019:
  • New: Test mode for the membrane
  • New: Compensation of the loop height differences
  • New: Alarm for daily re-pumping time
  • Bugfix: Interval of the level measurement
  • Bugfix: Adaptive pressure
  • Bugfix: False alarms on pressure changes due to adaptive pressure presets
  • Bugfix: Statistics, re-pumping times
  • Bugfix: Not always pumped up to the pressure set point
farbwerk nano Firmware 1024:
farbwerk 360 Firmware 1024:
  • Bugfix: Incorrect output with some effects
aquasuite X.64 (Insider) (14-DEC-2022)
  • Bugfix: Overview pages, display problems when rounding numbers
  • Bugfix: Playground, import of outputs
  • Bugfix: LEAKSHIELD statistics view
  • New: Safe mode for background service
aquasuite X.62 (Insider) (2-DEC-2022)
  • Bugfix: Firmware update process for mps and poweradjust
  • Bugfix: aquasuite startup
  • Bugfix: aquasuite web
aquasuite X.61 (Insider) (30-NOV-2022)
  • Update: Hardware monitoring (Ryzen 7000)
  • Bugfix: Autostart
  • Bugfix: Overview Pages
Notice:
The update directly from aquasuite X.60 or X.61 to a newer version only works if the aquasuite was started with administrator rights. Alternatively, the setup from the website can be used for the update.
This problem has been already fixed in newer versions.
aquasuite X.60 (Insider) (22-NOV-2022)
  • New: Porting of aquasuite from .NET 4.8 to .NET 7.0 (.NET Core)
  • Update: Performance improvements in the aquasuite application and Aqua Computer background service
  • Update: Bug fixes
The changes in the aquasuite are much more extensive this time than the changelog suggest.
Many functions have been rewritten or significantly optimized in terms of performance. In addition, the stability has been further improved. The new .NET 7.0 runtime environment is much more efficient than the previous versions.
Due to the large number of changes and adaptations, there will certainly still be a number of errors in X.60 despite many tests. For this reason, the current X.60 and the subsequent version will initially be published as an insider release.
The latest .NET 7 runtime for desktop applications must be installed to use aquasuite X.60.
https://dotnet.microsoft.com/en-us/downl…net/7.0/runtime
We will try to correct bugs as soon as possible with new versions.
There are no fimware updates included in the X.60 insider release. This allows you to switch back to the official X.59 version of aquasuite at any time. For this purpose, the setup from the download page must be used.
We ask for bug reports and feedback on X.60 and the following Insider versions. Please use this topic:
We wish you a lot of fun with the insider version and look forward to your feedback soon!
aquasuite X.59 (28-SEPT-2022)
  • Bugfix: AMBIENTpx may flicker if the monitor content does not change
aquasuite X.58 (26-SEPT-2022)
  • NEW: Time and date can be used as XAML element in overview pages (with examle preset)
  • Bugfix: Service high CPU load
  • Bugfix: RGBpx preview in controller settings
  • Bugfix: Playground, Inputs
farbwerk nano Firmware 1023:
farbwerk 360 Firmware 1023:
  • Bugfix: Flickering and errors with some effects
aquasuite X.57 (08-AUG-2022)
  • NEW: Playground, profile switch, delay on compare rule
  • NEW: Playground, new nodes: number rounding, table, counter, Exp, Log, Sin, Cos, Tan, Sqrt
  • Bugfix: Service
D5 NEXT Firmware 1024:
  • Update: Flow sensor settings
  • Bugfix: menu and interface
aquasuite X.56 (20-JUL-2022)
  • Bugfix: Playground import/export virtual sensors and outputs
  • Bugfix: Playground email notifications
aquasuite X.55 (13-JUL-2022)
  • Bugfix: Minor bug fixes in dialogs and the interface
LEAKSHIELD Firmware 1017:
  • Update: Improved measurement
aquasuite X.54 (05-JUL-2022)
  • Bugfix: LEAKSHIELD log
  • Bugfix: Wrong node descriptions
  • Bugfix: RGBpx controller settings
  • Bugfix: Numeric input
aquasuite X.53 (05-APR-2022)
  • Bugfix: D5 NEXT
D5 NEXT Firmware 1023:
  • Bugfix: If the RGBpx output is used, the fan or pump cannot be controlled
aquasuite X.52 (04-APR-2022)
  • Bugfix: Performance and stability improvements
  • Bugfix: Improved behavior with some NVIDIA graphics cards
high flow NEXT Firmware 1016:
D5 NEXT Firmware 1022:
LEAKSHIELD Firmware 1016:
  • Bugfix: Stability and device UI improvements
aquasuite X.51 (15-MAR-2022)
  • Bugfix: Merged fixes from insider versions X.48-X.50
high flow NEXT Firmware 1015:
  • Bugfix: Device settings
aquasuite X.50 (Insider) (24-FEB-2022)
  • Bugfix: Service and aquasuite performance (RAM, CPU load)
  • Bugfix: USB connection to devices*
  • NEW: CSV chart data export
  • NEW: automatic data export to CSV log file
  • Update: aquasuite userinterface
QUADRO Firmware 1032:
OCTO Firmware 1019:
farbwerk nano Firmware 1022:
farbwerk 360 Firmware 1022:
Vision RGBpx Firmware 1009:
D5 NEXT Firmware 1021:
high flow NEXT Firmware 1014:
LEAKSHIELD Firmware 1015:
  • Bugfix: USB connection issues*
*If the software sensors of the mentioned devices are not updated anymore or do not work after a while: please leave feedback in this topic.
aquasuite X.49 (Insider) (11-FEB-2022)
OCTO Firmware 1018:
QUADRO Firmware 1031:
LEAKSHIELD Firmware 1014:
  • Bugfix: Long pump runtime error detection
*If the software sensors of QUADRO, OCTO or LEAKSHIELD are not updated anymore or do not work after a while: please leave feedback in this topic.
aquasuite X.47 (04-NOV-2021 as Insider version; 16-DEC-2021 as regular release)
aquasuite X.46 (Insider) (27-OCT-2021)
  • Bugfix: Data logger and charts
  • Bugfix: HWiNFO data import
  • Bugfix: Profile switch units
  • Bugfix: Icon selection
  • Bugfix: QUADRO total power
aquasuite X.45 (Insider) (21-OCT-2021)
  • New: Playground Inputs
  • New: Playground Outputs, (previously notifications), no old settings are applied
  • New: Playground Profiles, no old settings are applied
farbwerk 360 Firmware 1020:
farbwerk nano Firmware 1020:
OCTO Firmware 1017:
QUADRO Firmware 1030:
  • NEW: Controller override/inputs support
LEAKSHIELD Firmware 1013:
  • Bugfix: Display invert behavior
  • Bugfix: Profile switching
  • Bugfix: Alarm when the PC is switched off
aquasuite X.44 (30-AUG-2021)
  • Bugfix: MPS data was not forwarded to other devices
aquasuite X.43 (25-AUG-2021)
  • New: In the Playground all modules can be activated and deactivated individually
  • New: Maintenance mode for the Playground
  • Change: Notifications within the aquasuite
  • Change: Firmware update process
  • Change: Aqua Computer service log
  • Bugfix: Playground automatic profile switching
  • Bugfix: Hardware monitoring settings
  • Bugfix: RGB input
LEAKSHIELD Firmware 1010:
VISION Firmware 1017:
VISION RGBpx Firmware 1008:
  • Bugfix: Display behavior in standby
aquasuite X.42 (28-JUL-2021)
  • Bugfix: Playground, Global profiles, LEAKSHIELD and Vision RGBpx
LEAKSHIELD Firmware 1007:
  • Bugfix: Alarm behavior
aquasuite X.41 (19-JUL-2021)
  • Bugfix: Playground, data sources are displayed with the name that was used when the data source was added
  • Bugfix: Data logger, error when units are changed
farbwerk 360 Firmware 1015:
farbwerk nano Firmware 1012:
vision RGBpx Firmware 1007:
high flow NEXT Firmware 1007:
OCTO Firmware 1015:
QUADRO Firmware 1028:
  • New: RGBpx effect color gradient with 2 to 4 colors
LEAKSHIELD Firmware 1006:
  • Bugfix: Test mode
  • Bugfix: Time scheduled refill
  • Bugfix: Detection in case of water on the membrane
aquasuite X.40 (23-JUN-2021)
  • New: LEAKSHIELD
  • Update: Playground calculates between nodes with full accuracy without rounding the intermediate results
  • Bugfix: Background service high CPU load
  • Bugfix: HWiNFO and AIDA64, search interval is reduced after a few minutes after system startup
  • Bugfix: farbwerk 360/nano, settings
aquasuite X.39 (10-MAY-2021)
  • New: Screenshot function
  • Bugfix: Data source selection
aquasuite X.38 (02-MAR-2021)
  • Bugfix: Playground, service crashes when automatic profile switching is enabled
aquasuite X.37 (01-MAR-2021)
  • Change: Hardware monitoring, NVIDIA Power Usage Sensor removed (NVIDIA driver bug)
  • Bugfix: Playground, MQTT connection errors
  • Bugfix: Memeory leak when USB devices are being unplugged and plugged
  • Bugfix: Communication between background service and aquasuite
  • Bugfix: Multiuser environments now also support AMBIENTpx and profile switching
aquasuite X.36 (26-JAN-2021)
  • Bugfix: Playground, Email issues
  • Bugfix: Playground, MQTT account without user name/password
  • Bugfix: Memory leak
OCTO Firmware 1014:
QUADRO Firmware 1027:
  • Changed: It is no longer necessary to disconnect the fans from the device to perform a firmware update
  • Bugfix: Fan starting behavior
  • Bugfix: Error detection
aquasuite X.35 (14-JAN-2021)
  • Bugfix: QUADRO und OCTO data cannot be used in the Playground
  • Bugfix: Firmware update procedure for QUADRO and OCTO has been adjusted
  • Bugfix: Background service may crash at system startup
OCTO Firmware 1010:
QUADRO Firmware 1024:
  • Bugfix: Rollback to last firmware version
high flow NEXT Firmware 1010:
VISION RGBpx Firmware 1006::
VISION Firmware 1016:
farbwerk nano Firmware 1011:
  • Bugfix: Error when loading the settings
D5 NEXT Firmware 1019:
  • New: Key lock
farbwerk 360 Firmware 1014:
  • Bugfix: LEDs may flicker at low brightness settings
  • Bugfix: Stability/compatibility with other LEDs improved
The aquasuite X.32, X.33, X.34 should not be used anymore and is no longer available (12-JAN-2021)
aquasuite X.31 (15-DEC-2020)
aquasuite X.30 (14-DEC-2020)
  • Update: Hardware Monitoring, Ryzen 5000 support
high flow NEXT Firmware 1009:
  • Bugfix: RGBpx, AMBIENTpx
aquasuite X.29 (Insider) (22-OCT-2020)
  • Bugfix: Service can crash on Windows startup
aquasuite X.28 (Insider) (20-OCT-2020)
  • Bugfix: Device list for audio source
farbwerk 360 Firmware 1013:
farbwerk nano Firmware 1010:
farbwerk Firmware 1009:
D5 NEXT Firmware 1018:
OCTO Firmware 1010:
aquastream ULTIMATE Firmware 1011:
  • Bugfix: RGBpx profiles
high flow NEXT Firmware 1008:
  • Bugfix: Water quality sensor
VISION RGBpx Firmware 1005:
VISION Firmware 1015:
  • Bugfix: Software sensor units
aquasuite X.27 (09-SEP-2020)
  • New: high flow NEXT
aquasuite X.26 (20-AUG-2020)
  • New: Device data import/export to file
  • Bugfix: AMBIENTpx settings for QUADRO and D5 NEXT
  • Bugfix: Playground notifications
aquasuite X.25 (03-AUG-2020)
  • Bugfix: Playground E-Mail settings
  • Bugfix: farbwerk profiles
D5 NEXT Firmware 1017:
OCTO Firmware 1009:
QUADRO Firmware 1023:
  • Improvement: PWM switch-on and switch-off behaviour adjusted for fans with high power consumption (particularly Noctua NF-A20)
aquasuite X.24 (Insider) (24-JUL-2020)
aquasuite X.23 (Insider) (16-JUL-2020)
farbwerk nano Firmware 1009:
farbwerk 360 Firmware 1012:
  • Bugfix: RGBpx color settings
aquasuite X.22 (29-JUN-2020)
  • Bugfix: Comment element in the playground crashes the background service
aquasuite X.21 (22-JUN-2020)
  • New: Test values for data sources
  • New: Playground element memory
  • New: Playground element to store the last sensor value
  • New: Playground element switch-on delay
  • New: Playground element switch-off delay
  • Bugfix: RGBpx keyboard navigation
VISION Firmware 1013:
  • Bugfix: Alarm settings for flow rate
aquasuite X.20 (Insider) (28-MAY-2020)
  • Bugfix: Hardware monitoring if several monitoring programs are used at the same time
aquasuite X.19 (Insider) (26-MAY-2020)
  • Note: All GPU sensors must be reassigned after the update (software sensors and overview pages)
  • Bugfix: Hardware monitoring GPU temperatures
VISION Firmware 1012:
  • Bugfix: Sensor data via aquabus have no unit
  • Bugfix: Display does not go off in standby
aquasuite X.18 (Insider) (20-MAY-2020)
  • Bugfix: Vision software sensor configuration
  • Bugfix: RGBpx datasource settings
  • Bugfix: Overview pages, display of the average value
farbwerk 360 Firmware 1011:
farbwerk nano Firmware 1008:
  • New: Effect scanner, laser and wave have an option for rotation and delay
  • New: Effect Sound firework
  • New: Effect firework
  • New: Effect shutter
  • New: Effect balls
  • New: Effect highlight
  • New: Effect stars
QUADRO Firmware 1022:
OCTO Firmware 1008:
  • Bugfix: Profile function
  • Bugfix: Start-up behaviour
D5 NEXT Firmware 1016:
  • Modification: Improved display brightness gradation
aquastream ULTIMATE Firmware 1010:
Vision Firmware 1011:
farbwerk Firmware 1008:
aquasuite X.17 (20-APR-2020)
  • Bugfix: Connection between aquasuite and Aqua Computer service
  • Bugfix: System load
aquasuite X.16 (07-APR-2020)
  • Bugfix: Update check
aquasuite X.15 (06-APR-2020)
  • Bugfix: Improved connection stability between service and aquasuite
  • Bugfix: Display error in the overview pages
OCTO Firmware 1007:
QUADRO Firmware 1021:
  • Modification: Fans start with a small delay at system startup to minimize load peaks
aquasuite X.14 (30-MAR-2020)
  • New: Notifications about updates in the Windows notification center
  • New: Overview pages of all devices in the new dark mode design
  • New: Layout templates for a sidebar
  • New: Layout templates with new design scheme
  • New: Updates hardware monitoring
  • Bugfix: D5 NEXT, QUADRO, OCTO, Sound data sources did not work properly
  • Bugfix: Missing unit for flow rate values via software sensor
  • Bugfix: No name change possible for the alarm levels of the aquaero
OCTO Firmware 1006:
QUADRO Firmware 1020:
  • Modification: Adjusted tolerance for undervoltage detection
aquasuite X.13 (03-MAR-2020)
  • New: Dark Mode
  • New: Ring element for overview pages
  • New: Bar graph with segments
  • New: Hardware monitoring has been updated
  • Bugfix: Hardware Monitoring
  • Bugfix: Start delay for the service was ignored
D5 NEXT Firmware 1015:
  • Bugfix: AMBIENTpx, problem with USB connection
  • Bugfix: Starting power / fallback power
QUADRO Firmware 1019:
OCTO Firmware 1005:
aquasuite X.12 (19-FEB-2020)
  • New: D5 NEXT, new layout for RGBpx settings
  • New: QUADRO, new layout for RGBpx settings
  • New: Performance Improvements
  • Bugfix: RGBpx, data sources were partially scaled incorrectly
  • Bugfix: RGBpx, not all controllers work with audio data sources
D5 NEXT Firmware 1014:
ATTENTION: All current device settings and profiles become invalid with this update!
  • New: Number of controllable RGBpx LEDs increased from 64 to 90
  • New: Number of LED controllers increased from 5 to 8; 6 at the RGBpx output and 2 for the pump
  • New: Adjustable fall-back power for fan output (e.g. for missing sensor data at system startup)
QUADRO Firmware 1018:
  • New: Number of LED controllers increased from 4 to 8
  • New: Number of Software sensors increased from 8 to 16
OCTO Firmware 1004:
  • Bugfix: Alarm switch-off with the power button option
  • Bugfix: AMBIENTpx only controlled the first 64 LEDs
farbwerk 360 Firmware 1010:
farbwerk nano Firmware 1007:
  • New: Settings for standby behaviour, LEDs can be automatically deactivated when the USB connection is not active anymore
aquaero 5/6 Firmware 2104:
  • Bugfix: aquabus error when several devices are in use
aquasuite X.11 (20-DEC-2019)
  • Bugfix: RGBpx, faulty scaling/output when using data sources
aquasuite X.10 (Insider) (18-DEC-2019)
  • New: Support of the OCTO fan controller
  • Bugfix: Memory leak at the desktop pages
  • Bugfix: aquasuite crash at the color picker dialog
  • Bugfix: Quickview of statistic data
  • Bugfix: Error when copying LED controller settings
aquaero 5/6 Firmware 2103:
  • New: OCTO aquabus integration
D5 NEXT Firmware 1012:
QUADRO 360 Firmware 1016:
farbwerk 360 Firmware 1009:
farbwerk nano Firmware 1006:
  • Bugfix: LED controller "rotating rainbow" could freeze
aquasuite X.9 (Insider) (04-DEC-2019)
  • New: Manual update check (button)
  • Improvement: Unit system of the aquasuite has been revised
  • Bugfix: farbwerk 360 and farbwerk nano; not all data and settings were displayed correctly when copying controllers
  • Bugfix: Several bugs in the playground
  • Bugfix: mps devices; incorrect settings when changing the device type
  • Bugfix: Incorrect displaying of the update service
VISION Firmware 1010:
  • Improvement: Unit system adjusted to the unit system changes of the aquasuite
aquasuite X.8 (Insider) (15-NOV-2019)
  • Bugfix: Error in the tray tool for profile switching
aquasuite X.7 (Insider) (13-NOV-2019)
Please note: AMBIENTpx and sound settings must be reassigned in the RGB controllers after the update.
  • New: Further logic elements for the Virtual Software Sensors
  • Improvement: Virtual Software Sensors can only be deleted via the menu
  • Bugfix: Import of overview pages
  • Bugfix: D5 NEXT Firmware language German/English was swapped
  • Bugfix: Log data can not be deleted
  • Bugfix: Configuration of the power measurement with aquaero
  • Bugfix: Missing icons
QUADRO Firmware 1015:
  • Bugfix : Profile management
D5 NEXT Firmware 1011:
aquastream ULTIMATE Firmware 1009:
  • Bugfix: Alarm evaluation was not active
aquasuite X.6 (Insider) (16-OCT-2019)
  • Bugfix: Name mapping for VISION did not work
aquasuite X.5 (Insider) (14-OCT-2019)
  • Announcement of the aquasuite X.5 with further details
  • New: Virtual Software Sensors
  • New: Global Profiles
  • New: Hotkeys with actions
  • New: Sorting of overview pages and devices is possible
  • New: Updated hardware monitoring
  • New: Video and audio analysis can be activated separately
  • New: QUADRO - profile management
  • New: D5 NEXT - profile management
  • New: aquastream Ultimate - profile management
  • New: VISION - profile management
  • New: farbwerk - profile management
  • Improvement: Increased stability of USB connection (affected only a few customers)
  • Improvement: Many small improvements to the user interface
  • Bugfix: Crash when all overview pages have been deleted and a a new page was added afterwards
  • Bugfix: Removed automatic range adjustment for some units (e.g. jumping between MHz and GHz)
farbwerk 360 Firmware 1008,
farbwerk nano Firmware 1005:
  • Bugfix: Effects "color sequence" and "wave" hang up when a data source is used for controlling
QUADRO Firmware 1014:
  • New: Adjustments for profile management
D5 NEXT Firmware 1008:
  • New: Option for inverting the display
  • New: Automatic inverting of the display is enabled by default
aquastream Ultimate Firmware 1008:
  • New: Display page with water temperature and flow rate
VISION Firmware 1009:
farbwerk Firmware 1007:
aquasuite X.4 (2019-JUL-09)
  • New: Updated Hardware Monitoring
  • Bugfix: Problem when system uses cyrillic, korean etc.characters
aquasuite X.3 (2019-JUN-26)
  • Bugfix: Button sensitivity calibration for aquaero 5/6 XT
  • Bugfix: Error in the layout of the update page
  • Bugfix: aquasuite web error when the data sources have the same names during export and import
  • Bugfix: Software sensors - error when using different offset and factor values
aquaero 5/6 Firmware 2102:
  • Bugfix: Faulty menu functions
aquasuite X.2 (Insider) (2019-JUN-19)
  • Bugfix: Copy/Paste problem on overview pages
  • Bugfix: Layout
D5 NEXT Firmware 1006:
  • Bugfix: Pump power was not shown on corresponding display page
aquasuite X.1 (2019-JUN-13)
  • Bugfix: Bug in the RGB controllers of farbwerk 360 and nano
  • Bugfix: Several minor bugs and optimizations
Changelog for older aquasuite versions
