• 06.10.2026, 23:59
Elior77
Aquasuit guide for best cooling vs noise ratio
Friday, February 5th 2021, 6:45pm
Target: best possible cooling while maintaining low noise level.
Tools:
Monitor and control:
* Aquaero 5/6
* Quadro
* Octo
Inputs:
* Ambient temperature
* Radiator OUT temperature
Fans:
* PWM Fans - recommended
Tuning procedure:
Find high limit for the pump (if noisy), max speed while noise level is acceptable. (in my case 60% is fast enough and quite enough).
Find the low and high limits of your rad fans.
Low limit is when the fan will not spin any more, so just above that (in my case 20%).
High limit is like with the pump, the highest speed possible while maintaining low level noise (in my case 50%) and while able the keep DeltaT<=MaxDeltaT* (less or equal max ambient vs rad out delta)
Configure a virtual sensor that gives the difference between the ambient temp and the rad out temp - Delta T
Now you need to find the Maximum Delta T you allow for your system.
You can start by setting the fans to 100% and running a typical game load, this will give you the lowest achievable DeltaT by your system.
Now try settings the fans at the high limit you have found and run a typical game load, this will let you know if the fans high limit is enough for stable operation.
You should aim for the lowest possible DeltaT.
Desired lowest Max Delta T will give:
Acceptable noise level - rad fans speed lower then the high limit.
Stable system - at max OC.
My system:
CPU: 10600KF @ 5.3GHz
3070 on air, waiting for the water block, it will be interesting to see how it will impact the tune, used to run 7700K @ 5ghz + 2070S on the same water loop - same tune.
EK-QuantumX Delta TEC
420mm Radiator
6x140mm Fans
Pump @ 60%
Fans low limit 20%
Fans high limit 50%
Ambient 22C
Idle:
DeltaT 3-4C
Fans @ ~20%
Games Load:
DeltaT ~8C
Fans @30-40%
Noise level: Super quite :) - almost no noise at all, 60cm~ away from the rad fans.
If you can NOT tune your system to be OC stable in games while maintaining low noise level, your radiator/s is/are not enough.
Let me know if it helps or more details are needed,
Cheers !
Elior
Why Ambient vs Rad out ?
The lowest possible water temp that can be reached is ambient temp, monitoring and controlling the cooling system through this parameter is the most effective way.
The components temp is derived from the coolant temperature.
Controlling using CPU or GPU temp is too erratic and will cause the fans to oscillate.
In total this is the absolute best parameter to rely on.
Elior77 has attached the following images:
This post has been edited 4 times, last edit by "Elior77" (Feb 6th 2021, 8:36am)
xdecock
Friday, February 5th 2021, 9:36pm
Won't this curve oscillate ? If the diff is in vs out it will rise when your coolant temp will rise better delta with ambiant, and you'll have a positive feedback loop as your cooling power also rises with the higher fan speed.
When your coolant temp falls down your fans will slow down too starting the cycle again.
My instinctive idea is that this will provide instable fan speed around the optimal settings.
Could this be a behavior you encounter?
xdecock
Friday, February 5th 2021, 9:40pm
Missread this is ambiant i was persuaded it was rad in vs rad out. I'm obviously exhausted.
cptninc
Saturday, February 6th 2021, 6:20pm
This seems very complicated. I would just set a target coolant temp and let the controller run its PID loop to maintain that.
Elior77
Saturday, February 6th 2021, 6:36pm
I tried what you suggest for a while, the problems are :
  1. Fans speed is not limited - can cause noise
  2. PID behavior is not as smooth as the curve I use.
  3. PID does not start raising the fans speed until the set temp is reached - fans will start too high and too late.
  4. Target coolant is not absolute, it is relative to ambient temp.
There for you should use my tune in order to get the best cooling vs lowest noise.
You must use DelteT, Max DeltaT, pump and fans low and high limits.
It is not that complicated.
Similar threads
