• 14.10.2026, 08:21
Ujin
3090 Strix active backplate thermal pads question
Tuesday, February 9th 2021, 5:13pm
Hey!
I just received a waterblock and active backplate for the 3090 Strix.
I'm a bit confused about the thermal pads used for the backplate.
Here are the pads that were included:
https://imgur.com/a/RDjLUep
In the picture, the top pads are the thicker ones (2mm?) and the bottom ones thinner (1mm?)
And here is the manual:
https://imgur.com/a/bXHjX6W
According to the manual, the thick pads go to the green areas (back of the GPU die and VRMs) and the thin ones go on the red (memory).
I don't quite understand how I'm supposed to cover the rightmost green area with the ticker pads that I received.
I've read in the German forum that someone had 3 thick and 3 thin pads rather than 1 and 5 respectively like I have.
Have I been sent the wrong pads or am I understanding something incorrectly?
Any help would be much appreciated, thanks!
Ujin
Wednesday, February 10th 2021, 2:23pm
I contacted support, turns out I was send the wrong thermal pads :(
Thursday, February 11th 2021, 6:56am
Did you received a replacement?
Ujin
Thursday, February 11th 2021, 9:08am
They are out of stock unfortunately, they said they will send me the replacement pads as soon as they have them available.
cptninc
Wednesday, March 24th 2021, 6:44pm
Did they say what the correct pad thicknesses are?
PiotrMKG
Thursday, March 25th 2021, 12:20am
cptninc
Wednesday, March 31st 2021, 2:44am
I might have also received the wrong pads. There are three thicknesses in my kit: the thick pre-cut pads, three medium rectangles, and three thin rectangles. Which of the rectangles should I be using?
[img]https://forum.aquacomputer.de/index.php?page=Attachment&attachmentID=8340&h=861d2e666ae0366c6232f845e8bcddbec580055f[/img]
[img]https://forum.aquacomputer.de/index.php?page=Attachment&attachmentID=8341&h=fb58304e4e03fb076231705b5b4964a8fe1434bf[/img]
cptninc has attached the following files:
cptninc
Monday, April 5th 2021, 4:22am
For the record, the thin ones (1mm) are the correct ones for the red areas. I checked with calipers, and the memory is 1.25mm tall and the backplate spacers are 2mm. This leaves a 0.75mm gap, which would be 25% compression on the 1.0mm thermal pads (the thinnest of the three) in the bag.
