• 14.10.2026, 04:29
PiotrMKG
Repacing thermal pads in rtx 3090 strix active backplate
Friday, March 12th 2021, 2:26pm
Hello,
I would like to replace original Kingbali 9902 Series Thermal Conductive Pad with gelid ones. Thin pads are 1mm but thicker ones are 1.8mm so I have to decide if I should go with 1.5mm or 2mm ones. Thanks for help.
Piotr
This post has been edited 1 times, last edit by "PiotrMKG" (Mar 25th 2021, 12:23am)
PiotrMKG
Monday, March 15th 2021, 2:46pm
Can someone from AQ (maybe Shoggy) tell me, what are designed clearances between RAM, PCB and other places where thermalpads are used and backplate?
Monday, March 15th 2021, 4:03pm
Were this me, I would opt for the 2mm version.
There is most probably 0.2mm of compression available in the 2mm thermal pad, but if the 1.5mm thermal doesn't make contact, you have fail.
PiotrMKG
Monday, March 15th 2021, 6:01pm
There has to be 0.2mm compression, thermalpads have to have 10% of compression to make proper contact. 2mm thermalpad should be good for clearances of 1.4 to 1.8mm. 1mm should be good for gaps ranging from 0.45mm to 0.9mm
