• 28.09.2026, 17:16
muqqenz
Question about ultitube multitop
Tuesday, April 20th 2021, 1:20pm
Ok, the question might be dumb, but I can't for the life of me figure out how to fit the acryl tube into any of the fittings on the bottomside of this top.
This it the top: https://shop.aquacomputer.de/product_inf…roducts_id=3943
The tube seems to go in a few millimeters, but does not properly attach, meaning i's not secure at all, and a slight movement will dislodge it. I've used inhumane amounts of strength to push it into the fitting, but it just won't go in far enough. Am I missing something here? What am I doing wrong.
Tuesday, April 20th 2021, 3:55pm
You are probably having trouble getting the tube to go past the O-ring in the port. oring.jpg
Place a sheet of fine sandpaper on your desk, and holding the tube at about 45 degrees, lightly rotate/sand the outer edge of one end giving it a slight bevel.
This post has been edited 1 times, last edit by "InfoSeeker" (Apr 20th 2021, 3:57pm)
