• 01.10.2026, 04:19
WinstonWoof
Aquasuite X.41 Temp Sensor Misreporting
Saturday, July 24th 2021, 11:32am
SInce upgarding to X.41 as simple calculation steps to display Delta temps are returning negative values.
Actually looking at it It appears to be be misreading the Ambient Temp as 100
NB I still have X.39 on the other W10 install on this same PC and that is reporting the ambient temp correctly so not hardware issue
WinstonWoof has attached the following file:
WinstonWoof
Saturday, July 24th 2021, 11:34am
Just noted that according to ASX.41 firmware also requires update.
Will try that and report back
  • Firmware.JPG (75.9 kB - 76 times downloaded - Last download: Yesterday, 3:30pm)
WinstonWoof
Saturday, July 24th 2021, 11:43am
Upgrading the firmware has resolved the temp sensor reading issue in X.41 although, as anticipated, the other W10 install running X.39 is now reading ambient as 100c instead.
Little tip for the developers .
If a version of the software is firmware dependent then during software install you should be prompted to also upgrade the firmware/carry out firmware upgrade as part of software upgrade.
(And please don't tell me that its hidden in a changelog that the firmware has to also be upgraded as that is not a User Friendly way to do it)
WinstonWoof
Saturday, July 24th 2021, 11:52am
On the Changelog front it (English and German) hasnt been updated since Jan 2021 and has X.30 as the latest version
aquasuite changelog - English
This post has been edited 1 times, last edit by "WinstonWoof" (Jul 24th 2021, 11:53am)
Saturday, July 24th 2021, 12:26pm
You found a discontinued thread.
Here is a link to the current CHANGELOG, which is linked on the SOFTWARE DOWNLOAD page.
WinstonWoof
Saturday, July 24th 2021, 12:53pm
Ta
Still needs tidying up though.
The thread I found was the most recent in the sub forum immediately above this one
  • Capture.JPG (66.73 kB - 96 times downloaded - Last download: Yesterday, 6:28pm)
WinstonWoof
Saturday, July 24th 2021, 12:54pm
and also not its not hidden in what is currently a 27 page (& expanding thread)
The changelog I found is easy to digest and find as it cant be commented on unlike the (helpful) link you provided
