• 14.10.2026, 02:44
erniuss
Quadro arrived faulty ?
Tuesday, February 8th 2022, 9:11pm
Hi there , wondering if anyone has an issue that quadro wont be recgonised/ wont work ? .
I have tried pluggin in all 4 and just 1 pwm fans however when PC boots none spinning ( not connected to the usb) It does not give me any LED light or anything as it does say manual .
I tried connecting to both of my USB slots none detecting it while trying to install aquasuite.
I tried running single aquasuite on just single molex cable with nothing else connected .
So is theres something that i could do to fix it or it is pretty much faulty product ?
Remayz
Wednesday, February 9th 2022, 10:13am
maybe double check that the USB connection is plugged the right way to the motherboard?
it's easy to put it the wrong way since it's a half USB connector.
tha black wire goes on the side of the motherboard header where a pin is missing (top row or bottom row, doesn't matter)
erniuss
Wednesday, February 9th 2022, 12:46pm
i did check unfortunately same issue , thing is that i would forget about the USB at the moment as ive asked in groups and checked online the quadro should whether its plugged in or not , and as stated above with fans plugged in none are spinning :(
Hufeisen
Wednesday, February 9th 2022, 7:39pm
Make sure that the Molex Power Connector on the Quadro is connected properly.
The Quadro requires 5V and 12V Power from the Molex Connector.
erniuss
Wednesday, February 9th 2022, 9:38pm
how can i do that ? its literally just 1 cable right , and it should go the right way in as it has the little corner shaped so it has to match with molex connector . I did try to replug and run like 10 times but yea , nothing .
Thursday, February 10th 2022, 1:03am
Do you have a DC volt meter that you can use to measure the 12VDC and 5VDC on the Molex connector? Did you make sure the other end is plugged into your power supply?
erniuss
Thursday, February 10th 2022, 8:15am
i dont have meter, however what happened is at the first time i tried boot my system ( 3700x ,5700 , 6 Corsair ll fans and 2x D5 PUMPS all connected at once with quadro , my power button would just not work , PC wouldnt even attempt to boot itself , the second i disconnected quadro PC booted up no issues .
Thursday, February 10th 2022, 7:57pm
May be time to communicate with support: support@aqua-computer.de
erniuss
Wednesday, February 16th 2022, 7:37pm
i did sent them an email however no response for over a week so far :(
Wednesday, February 16th 2022, 10:04pm
There is a notice on their support page:
Quoted
PLEASE NOTE:
Due to a high volume of inquiries, it currently takes up to two weeks to respond to e-mails.
I have never had them not reply.
Wednesday, February 16th 2022, 10:49pm
]i dont have meter, however what happened is at the first time i tried boot my system ( 3700x ,5700 , 6 Corsair ll fans and 2x D5 PUMPS all connected at once with quadro , my power button would just not work , PC wouldnt even attempt to boot itself , the second i disconnected quadro PC booted up no issues .
Yeah that sounds like the Quadro has a problem. Only other thing I can think of - I recall a post form someone who used the screws Aquacomputer provides with the fan controller to mount it to his case. He ran the screws through the case metal then up into the controller. One of the screws was touching the back of the circuit board and shorting something out. I may not be describing this accurately (going from memory) but the main idea is that the way he mounted his fan controller resulted in a mounting screw touching the back of the circuit board which was causing his problem. Do you have the Quadro mounted with screws? If yes, try removing them.
erniuss
Thursday, February 17th 2022, 9:53am
na i never had it with screws it was always sort of hanging on other cables .
This post has been edited 1 times, last edit by "erniuss" (Feb 17th 2022, 10:11am)
Thursday, February 17th 2022, 6:18pm
OK. I just thought I would throw this out there. Hopefully Aquacomputer support will respond to you soon. Good Luck!
Hufeisen
Thursday, February 17th 2022, 10:43pm
Probably a short circuit somewhere on the Quadro, or the devices connected to it. The power supply detect the short circuit and refuses to turn on.
The Quadro is most likely dead now because the internal fuse is blown and need to be replaced.
If you are good with a soldering iron, you can do this in a few minutes.
Hopefully you get a replacement device...
