• 29.11.2026, 02:59
psychotik2k3
[solved] Highflow next through Quadro indicates 16X the real flow
Friday, July 29th 2022, 5:00pm
Hi i have a high flow next that i plugged both on usb and a flow input of a quadro (my quadro is plugged both in usb and aquabus to an aquaero 5)
on aquasuite while the hgighflow indicates 106l/h on the quadro (and then on the aquaero) it indicates 1775l/h
on the quadro when i go to the sensor i cannot change to the correct value, i have the choice for older aquacomputer flowmeters not the next.
i checked on the doc again and there is no limitation about that.
This post has been edited 1 times, last edit by "psychotik2k3" (Jul 30th 2022, 12:17am)
Friday, July 29th 2022, 5:12pm
Please check if you have selected the right option.
psychotik2k3
Saturday, July 30th 2022, 12:16am
thanks that was that.
Saturday, July 30th 2022, 7:22pm
I am confused. How can you have a Quadro connected to USB and to an Aquaero via Aquabus? I thought if you connected a Quadro or an Octo to an Aquaero via Aquabus, the fan controller becomes a slave to the Aquaero and would not longer appear as a separate device in Aquasuite. Is it OK to connect a Quadro or Octo with USB and to an Aquaero via Aquabus at the same time?
Jacob
RE: [solved] Highflow next through Quadro indicates 16X the real flow
Sunday, July 31st 2022, 12:01pm
Quoted from "'that.[/quote"
You don't need to connect high flow to aquaero with aquabus that would result in a detection error,
Use aquaero's information pages to select the correct signal high flow number :)
Bartdude
Monday, August 1st 2022, 6:25am
Yes you can connect both at the same time
Monday, August 1st 2022, 7:36pm
OK thank you. I thought that the Aquabus connection and the USB connection were exclusive to each other.
Monday, August 1st 2022, 8:26pm
If memory serves, having the octo/quadro aquabus connected to the aquaero, does slave the pwm ports to the aquaero. Doing so essentially excludes the fan controllers from the octo/quadro for a total of 4 controllers (aquaero only), instead of 12/8 possible controllers. (octo 8 + aquaero 4 or quadro 4 + aquaero 4)
