• 14.11.2026, 21:58
bigjimmyauk
Help with RGBpx settings
Sunday, October 30th 2022, 9:54pm
Hi all
So i have 2 of the 15 led strips linked together with a 4cm cable to connect them together but for the life of me i can't get them to chase each other around. example if i set channel 1 and 2 to laser both strips start at the same time. i'm wanting the first strip to start then the second to start when the laser effect gets to the end of strip one like you would see with just one continuous strip. Is this possible or is it a limitation of using this method. i currently have a quadro in this system only so only have the one rgbpx output.
many thanks
bigjimmyauk
Sunday, October 30th 2022, 10:05pm
ignore me i didn't realise you can expand the selction of LED controller 1 to cover all 30 LEDS i was trying to use 2 controllers to do it lol
thanks anyway
