• 12.11.2026, 18:30
klara
ULTITUBE without filter element?
Wednesday, May 3rd 2023, 8:23am
In order to clean ULTITUBE filter, I have to drain water from the reservoir and since this is very inconvenient, I am using in-line filter with combination of QDC.
So, I do not need filter element and it would be best to remove it if possible because any filter would act as restriction in loop.
However, since it is rubber, I suspect that it is also a o-ring like sealing part for the reservoir and in that case, I cannot remove the filter element simply.
Is it possible to use ULTITUBE reservoir without filter element?
If I need additional part to replace the filter element position, which one should I buy?
CaptainOblivious
Wednesday, May 3rd 2023, 8:41am
Hmm. Found an interesting discussion related to this that may interest you. There are a lot of others if you do some searching as well.
It makes me wonder if an in-line filter is better than the utilitube filter. It could be that an inline filter actually increases the flow restriction more than the built in utilitube filter.
I don't know. Just a thread I found while googling your interesting question.
https://www.reddit.com/r/watercooling/co…s_like_such_an/
CaptainOblivious
Wednesday, May 3rd 2023, 8:42am
Also, I would assume this is the filter replacement you would use if you were to use one, but I may be wrong. I am very new to Aquacomputer and PC build. I'm sorry I cannot answer your first question, but like you I would tend to think you should not remove the filter entirely as it may likely cause a leak or other issue as it is likely not designed to be used without the filter in place. Just my guess.
https://shop.aquacomputer.de/product_inf…roducts_id=3860
This post has been edited 1 times, last edit by "CaptainOblivious" (May 3rd 2023, 8:44am)
Top_Nurse
Wednesday, May 3rd 2023, 3:39pm
You need to leave the rubber filter assembly in place as it seals the bottom of tube. I am planning to get a sharp x-acto knife and cut out the filter. My suggestion is to get a new filter part before you start cutting so in case you screw the pooch you got a backup solution. 8)
Wednesday, May 3rd 2023, 6:29pm
You can remove the filter with a sharp cutter. It's also possible to use the replacement part for the lid seal also instead of the filter. But I recommend to remove the filter if needed as the water flow will not be changed due this.
