• 22.11.2026, 23:27
yoshig
Service can't start
Friday, September 22nd 2023, 10:19pm
I have the latest aquasuite X75 and the service suddently doesn't start.
I have reinstalled it multiple times, clean install too, same deal.
I tried safe mode, with admin rights, nothing works.
How can I find what is going on?
yoshig
Friday, September 22nd 2023, 10:33pm
I tried to manually start the service from the services msc, but I get an error
Error 1068: The dependency service or group failed to start
yoshig
Friday, September 22nd 2023, 10:48pm
Digging a little more into the event viewer, I get this message when I try to start the service:
"The Aqua Computer Service service depends on the DNS Client service which failed to start because of the following error:
The service cannot be started, either because it is disabled or because it has no enabled devices associated with it."
yoshig
Friday, September 22nd 2023, 11:44pm
I have trouble starting this service, and I am wondering why does AquaSuite need the DNS caching service?
At this stage all of my other applications work fine without it, can AquaSuite be somehow configured from requiring this service, to using it only if it is available?
I mean I just want to control my fans in the end. I understand the network connection requirement for licencing checking, update checking etc, and there is network, but why the DNS cache?
The DNS client service description from Microsoft reads:
"The DNS Client service is used to resolve DNS domain names, by querying locally cached information obtained from a previous query or byquerying a remote DNS server."
The DNS Client service description from services msc reads:"The DNS Client service (dnscache) caches Domain Name System (DNS) names and registers the full computer name for this computer. If the service is stopped, DNS names will continue to be resolved. However, the results of DNS name queries will not be cached and the computer's name will not be registered. If the service is disabled, any services that explicitly depend on it will fail to start."
This post has been edited 3 times, last edit by "yoshig" (Sep 24th 2023, 3:32pm)
yoshig
Wednesday, November 8th 2023, 11:58pm
It seems that this post does not have any responses. Is there somewhere else I could ask this?
Thursday, November 9th 2023, 3:35am
Your best bet is probably support@aqua-computer.de
Thursday, November 9th 2023, 7:17am
What is not clear?
If the service cannot start because a dependency is not fulfilled. You have to configure your Windows so that it works.
The aquasuite runs with every standard Windows installation, if you deactivate services and functionalities in Windows there can always be problems.
Test with a new windows installation, if it works then you know where the problem is.
yoshig
Friday, March 1st 2024, 12:23pm
Hi @sebastian
It's unclear why Aquasuite relies on this service, especially when other applications can run without it.
Moreover, there's a question as to why this software should require the DNS service to operate.
Additionally, your proposal to test it with a new Windows installation seems disproportionately extreme.
Friday, March 1st 2024, 2:18pm
Quoted
I think the answer to the why is clear, because it was programmed that way, you will hardly find out what the programmer was thinking, with any provider.
Troubleshooting with a fresh Windows, on the other hand, is a completely normal step that has been used for a long time, so you can rule out or confirm that the malfunctioning software is the source of the error and then, if necessary, find the actual source of the error by installing individual programs/drivers.
In a grown Windows, however, troubleshooting is extremely complicated and therefore much more extreme than a second HDD/SSD with a quickly installed Windows.
Translated with DeepL.com (free version)
