• 07.10.2026, 18:47
bjcsoln
Hi-Flow Next - Water Quality / Conductivity results
Tuesday, January 30th 2024, 8:16am
So, loop has been running for about a week, running distilled water + EK Cyrofuel clear. Water quality is ready about 20% and conductivity around 95uS/cm.
Is this anything I really need to monitor? Should I expect variations depending on what fluid I use? Am tempted to throw in something like DP Ultra (I need to replace one piece of the loop) just to see if the reading change but anyway, I thought I would ask if / how important these settings are, what should I be targetting / what can I control.
THanks!
Remayz
Tuesday, January 30th 2024, 9:45am
the conductivity sensor is more or less useless for coolants like the Cryofuel, or other non-glycol based concentrates. the reading will be high from the start.
if you switch to DP ultra (after a thorough flush) the reading should drop way down and the sensors will make sense.
Bartdude
Tuesday, January 30th 2024, 11:40am
I've been using EK Cryofuel clear premix for the last few months and my HF Next says everything is in the green, 100% quality...
Remayz
Tuesday, January 30th 2024, 12:17pm
hmm. i'm just commenting from the experience of others, having very high conductivity reading.. but maybe it was tweaked in software since then?
Bartdude
Tuesday, January 30th 2024, 12:43pm
This is the premix, the concentrate that you mix with DI could be totally different
The HIgh Flow Next conductivity sensor will not work with EK Cryofuel
Tuesday, January 30th 2024, 7:12pm
That is surprising because the conductivity of Cryofuel is far higher than the conductivity sensor in the High Flow Next can measure. What conductivity value is the sensor reporting? The sensor can measure from 2uS/cm to 200uS/cm. Note the “u” means micro. EK claims Cryofuel has "low electrical conductivity". The product WEB PAGE states that the conductivity of Cryofuel is 1.4 mS/cm which is 1040 uS/cm. This is ~5X higher than the conductivity sensor can measure.
I agree, There was a long discussion about this on the English forum in 2021. Someone was using Cryofuel and could not understand why the conductivity sensor in their High Flow Next was not working properly. The conversation begins HERE with a post from torexko and continues through the thread with posts about other things mixed in. He contacted EK who STATED that the initial conductivity of Cryofuel is actually ~2330 uS/cm, which is ~11.6X higher than the sensor can measure. Cryofuel’s corrosion inhibitor is sodium 2-ethylhexanoate. Conductivity starts out very high and decreases as the inhibitor forms a protective coating on metal surfaces. It stabilizes around 1040 uS/cm.
DP Ultra’s conductivity starts out very low at ~10 uS/cm and increases over time. When it gets up to ~100 uS/cm, Aquacomputer recommends replacement. They expressed the opinion that using a coolant with 1000uS/cm is like using RIVER WATER and using a highly conductive coolant can accelerate corrosion and cause very bad things to happen if it gets onto an energized circuit. They also STATED that the conductivity sensor in the High Flow Next will not work with Cryofuel due to its very high conductivity. If you want the conductivity sensor to work properly, use DP Ultra.
Bartdude
Sunday, February 4th 2024, 11:24am
Here's a SS of my setup with water quality etc
Bartdude has attached the following image:
Monday, February 5th 2024, 2:09am
I don't know why you are getting that low value for conductivity with Cyrofuel. Aquacomputer specs for the High Flow Next say the sensor can measure from 2 to 200uS/cm. EK specs for cryofuel says conductivity is 1.04mS/cm (1040uS/cm) +/-10% That is way beyond the maximum value that the sensor can measure. There are many ways to measure flow rate but AFAIK, there is only 1 way to measure conductivity of a fluid. A voltage is applied so current flows between 2 (or sometimes 4) electrodes that are immersed in the fluid. The sensor calculates the resistance of the fluid by measuring the voltage drop across the electrodes and applying Ohm's Law. Conductance is the reciprocal of resistance The measured value is converted to conductivity by applying a calibration curve or formula specific to the sensor. Conductivity is affected by temperature so some conductivity measurement systems also include a temperature probe and apply a compensation value based on the measured temperature of the fluid.
Attempting to measure a fluid whose conductivity is much higher than the sensor can measure can cause a saturation effect that can cause the measurement system to become miscalibrated. Perhaps that is what is happening in your case. I suspect your Cryofuel's conductivity is not 15uS/cm. If is is, that would mean that the sodium 2-ethylhexanoate in the Cryofuel has been just about completely used up. Only Aquacomputer knows exactly what conductivity sensor is in the High Flow Next. Maybe one of them will chime in here.
