• 15.11.2026, 20:25
theruinedcity
D5 ULTITUBE FAN QUESTION
Sunday, June 16th 2024, 11:03pm
I was wondering if aquabus cable 4 pin #53122 will connect to the fan slot on my d5 pump and connect to the splitty 4?
Monday, June 17th 2024, 1:52am
I believe that would work, as long as the fans connected to the splitty 4 have a total power draw less than 25W, inclusive startup in-srush. aquacomputer appears to rate their gear for absolute maximum, not operating.
If you think you may exceed the 25W limit, you could use the splitty 12 active with the sata power connected to the PSU.
theruinedcity
Monday, June 17th 2024, 2:54am
Thank you! I'm using the AF120 RGB elite so they pull a total of 4.5 per 1. So 4 should be 20
