• 27.07.2026, 17:22
nebj00la
Aquasuite - Microstuttering in games while using an overview page
Wednesday, November 26th 2025, 3:19pm
I'm using a custom overview page to display fan/pump/temperature statistics on a small monitor. When gaming there are microstutters every time the polling of metrics takes place, to the point where the games are unplayable. I've tried forcing Aquasuite to use the iGPU, and it's the same result. Any possible workarounds? The metrics include LEAKSHIELD, etc., so they're critical to me.
Here's a video of the behavior: https://medal.tv/games/microsoft-flight-…DQ0MTU0MTk&v=12
Attached is a screenshot, it's low resolution but the detail is MainThread without Aquasuite is generally <10ms, when each polling cycle runs for metrics MainThread jumps to ~20ms and the game stutters.
Thanks,
nebj00la
nebj00la has attached the following images:
Wednesday, November 26th 2025, 4:45pm
The animation of the gauge element is known to cause performance hits. Try to disable it.
nebj00la
Wednesday, November 26th 2025, 10:29pm
[attach]11202[/attach]
Thanks for the prompt reply. I just disabled the animation function, though it was only an option with the fan/pump RPM gauges on the bottom right. I also tried removing the three gauges and the microstutters are still present. I was able to use the data export/aquacomputer service output combined with another overlay tool to get this working. The Aquasuite overview page has a much cleaner layout, so I'd be interested in troubleshooting more.
This post has been edited 3 times, last edit by "nebj00la" (Nov 26th 2025, 11:06pm)
