• 30.11.2026, 15:07
mo0nman
Ampinel connectors
Saturday, March 7th 2026, 12:08pm
Hello,
what material are the connector pins on the Ampinel? I have a Zotac 5090 OC Solid which has gold plated pins on the connectors. I know that tin and gold are a bad misk so wanted to know what the Ampinel device uses
Cheers :)
Saturday, March 7th 2026, 2:13pm
That's not a problem. Corrosion between tin and gold contacts can only occur in a few scenarios.
In a PC, it's almost impossible.
Don't let every YouTube clickbait video drive you crazy.
mo0nman
Saturday, March 7th 2026, 6:01pm
What scenarios would it occur in? I'm not going off of any youtube videos but rather this post from Molex themselves, as well as this Reddit thread .
Saturday, March 7th 2026, 9:21pm
Here is a LINK to a Technical Resource note from TeleWire, which is as ISO 9001 certified manufacturer of Test Leads, Wire Harness, and Cable Assembles. They also say mating Gold and Tin contacts is a no-no. A quick Google search returns that Galvanic Corrosion is not likely to occur in a PC DC power connector because it requires a liquid to act as a bridge between the Gold and Tin. The concern is Fretting Corrosion which is caused by microscopic movement of the contacts due to thermal expansion/contraction and fan vibration, which can occur in a GPU DC power connector in a computer. I don't know how long it would take for Fretting Corrosion to become a problem in this case, but it seems to be a valid concern because over time, it causes the Gold to oxidize into a resistive film.
mo0nman
Sunday, March 8th 2026, 2:57am
I wonder if I would be better off avoiding something like the Ampinel or Wireview and just use my PSU cable directly. I have the Lian Li 1300W Edge, which has a gold plated 12v-2x6 cable.
The alternative is that I buy the Ampinel and replace the connectors on it with gold plated ones. I'd have to find somewhere to do the modification since I am not confident in my soldering skills. The only problem is I cannot find gold plated connector pins in stock anywhere. I wonder if it's possible to harvest the connector from my spare gold-plated PSU cable?
Sunday, March 8th 2026, 12:57pm
This is not possible because the connector towards the GPU is permanently molded onto the circuit board.
