You are not logged in.
FuryriderX
Same here, arrived March 6 in Canada, and the import charges weren't bad at all either. Super happy. Worth the wait!Unit arrived last week and am VERY happy with the build quality and overall functionality. Top marks folks. Ordering process was a little bothersome with constant errors and timeouts from your webshop, but with the unit in hand that's easy to forget about.
How the heck did you all manage to snag one? I refresh my browser at least twice a day and it always show out of stock for me!Same here, arrived March 6 in Canada, and the import charges weren't bad at all either. Super happy. Worth the wait!Unit arrived last week and am VERY happy with the build quality and overall functionality. Top marks folks. Ordering process was a little bothersome with constant errors and timeouts from your webshop, but with the unit in hand that's easy to forget about.
TechBaguette
This post has been edited 1 times, last edit by "TechBaguette" (Apr 16th 2026, 2:51pm)
MTM
I have a MSI RTX 5090 Vanguard SOC + Alphacool Core + Ampinel Typ BDoes someone use it with a waterblock Alphacore Core for 5090?
I had compatibility problem with this kind of device when using a waterblock (wasn't able to correctly plug the wire view pro on it).
This post has been edited 3 times, last edit by "MTM" (Apr 16th 2026, 6:01pm)
TechBaguette
it fits for me.
and works great !
Good point. I didn't think of that. Usually, when items are out of stock on other sites, they can't be added to cart.How the heck did you all manage to snag one? I refresh my browser at least twice a day and it always show out of stock for me!
If you wait for the shop to be "in stock", you will have looong wait.
If you place an order, you will be in the production queue.
bofff
This post has been edited 1 times, last edit by "bofff" (Apr 18th 2026, 8:11am)
This post has been edited 1 times, last edit by "Speedy-VI" (Apr 19th 2026, 7:20pm)
LancerB1
Thursday, August 6th 2026, 3:30am
In addition to visual and audible alarms, a wide range of actions can be defined. These range from pop-up messages to automatic termination of software that causes a high GPU load, sending of definable hotkeys, shutdown of the PC, switching of alarm outputs, switching off of the Sense lines, and hard shutdown of the graphics card power supply via AMPINEL.
