• 16.07.2026, 03:23
FuryriderX
Mittwoch, 18. März 2026, 18:20
Unit arrived last week and am VERY happy with the build quality and overall functionality. Top marks folks. Ordering process was a little bothersome with constant errors and timeouts from your webshop, but with the unit in hand that's easy to forget about.
Same here, arrived March 6 in Canada, and the import charges weren't bad at all either. Super happy. Worth the wait!
aquaman2030
Donnerstag, 19. März 2026, 22:48
How the heck did you all manage to snag one? I refresh my browser at least twice a day and it always show out of stock for me!
Souls Collective
Freitag, 20. März 2026, 02:04
Stayed up late (wasn't a huge struggle, had to work late that night anyway) and camped the AC shop page at 4 p.m. UTC+1 at my local time equivalent, commenced refreshing, struggled through the shop grinding to a halt, rejecting orders, not loading page, removing items from cart, and generally carrying on (see page 2 of this thread). Finally able to successfully add to my cart as 'out of stock, delivery time up to 60 days' at about 30 minutes after launch.
Samstag, 21. März 2026, 14:45
If you wait for the shop to be "in stock", you will have looong wait.
If you place an order, you will be in the production queue.
TedBrosby
Dienstag, 7. April 2026, 02:59
I pre-ordered on March 19th.
Still waiting.
Did anyone order around that time and hear anything? I assume I'll be waiting until early May or so.
Excited to get this!
Dienstag, 7. April 2026, 14:55
Don't know if I should mention this for fear of overloading support... once you are in the production queue, send them an email and they may be able to give guidance as to availability for your unit.
ksenchy
Dienstag, 7. April 2026, 23:36
Looks like my unit was shipped today. It took 57 days. Stay patient guys :)
Kruxarn
Donnerstag, 16. April 2026, 13:37
I’m at 65 days now, so hopefully it ships soon. Order number:445012
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Kruxarn« (17. April 2026, 13:22)
TechBaguette
Donnerstag, 16. April 2026, 14:12
Does someone use it with a waterblock Alphacore Core for 5090?
I had compatibility problem with this kind of device when using a waterblock (wasn't able to correctly plug the wire view pro on it).
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »TechBaguette« (16. April 2026, 14:51)
MTM
Donnerstag, 16. April 2026, 17:43
I have a MSI RTX 5090 Vanguard SOC + Alphacool Core + Ampinel Typ B
it fits for me.
and works great !
»MTM« hat folgende Dateien angehängt:
  • MSI RTX 5090 Vanguard SOC.jpg (668,79 kB - 557 mal heruntergeladen - zuletzt: 12. Juli 2026, 22:50)
  • axa0.jpg (661,86 kB - 541 mal heruntergeladen - zuletzt: 12. Juli 2026, 14:36)
  • axa1.jpg (295,93 kB - 528 mal heruntergeladen - zuletzt: Gestern, 14:18)
  • axa2.jpg (902,78 kB - 548 mal heruntergeladen - zuletzt: 12. Juli 2026, 21:02)
  • Ampinel.jpg (1,18 MB - 553 mal heruntergeladen - zuletzt: 12. Juli 2026, 20:08)
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »MTM« (16. April 2026, 18:01)
TechBaguette
Donnerstag, 16. April 2026, 21:15
Thank you for your answer!
it fits for me.
and works great !
ksenchy
Donnerstag, 16. April 2026, 23:36
I put mine into my PC today. Matches my GPU great. Works well too
»ksenchy« hat folgende Datei angehängt:
aquaman2030
Samstag, 18. April 2026, 05:29
Good point. I didn't think of that. Usually, when items are out of stock on other sites, they can't be added to cart.
aquaman2030
Is the finished AMPINEL PCB exposed like the one pictured?
Samstag, 18. April 2026, 05:32
bofff
RE: Is the finished AMPINEL PCB exposed like the one pictured?
Samstag, 18. April 2026, 07:39
inno3d/bykski 5090
I ordered TypA despite in theory TypeB suit more, but as waterblock is quite tight and I have room only ion the bottom side of GPU I took risk. Luckily it suit
Excellent product but some minor tweaks might be done to improve it further
1 it loads basic screen on each boot instead of my own custom one
2. unlike in Octo, virtual sensors added to sensors section do not show up in HWinfo
3. Virtual sensor Max have only 1800sec memory
but overall, Im super happy wiith
»bofff« hat folgendes Bild angehängt:
»bofff« hat folgende Dateien angehängt:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »bofff« (18. April 2026, 08:11)
MTM
Samstag, 18. April 2026, 15:05
latest HWinfo version ?
they had a update last month to support the Ampinel.
Ampinel Competition
Sonntag, 19. April 2026, 04:24
I read that Asus has released their ROG Equalizer power protection system and Gigabyte has announced their T-Guard active load balancing system in their new GAMING series power supplies. Assuming that PCI-SIG does not finally decide to come up with a less stupid power connector, it seems like products like the Ampinel and the WireView Pro are going to have some competition from the big boys in the custom computer industry.
Edi to add MSI GPU Safeguard +.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Speedy-VI« (19. April 2026, 19:20)
MTM
Sonntag, 19. April 2026, 16:10
the problem is always this stupid small connector. :S
It's like a death star is firing 6 power beams on one small point.
They should simply scale up the connector with factor ~ x1,5 :whistling:
beside better cables and protection systems.
