• 22.11.2026, 20:30
Roburt88
Ampinel OLED screen turns off when idle, but never turns back on automatically.
Thursday, September 10th 2026, 1:13am
Hi! I just installed my Ampinel and I've found that after a couple minutes idle the OLED screen turns off. The screen turns back on if I open aquasuite or click the button on the Ampinel, but it doesn't turn back on automatically if the GPU load increases significantly (like when you play a game). Is this normal behavior? I just want to make sure the unit is working as intended. Thanks!
Thursday, September 10th 2026, 7:39am
this is correct. Idle means "no button is pressed", not idle load.
Roburt88
Friday, September 11th 2026, 7:09am
Good to know, thank you!
huntercrane69
Monday, September 14th 2026, 12:57am
So "idle" basically means "nobody touched the button". That explains it, but I can definitely see why people would read it as GPU idle. Slightly evil wording there
