• 22.11.2026, 21:17
Carbine
Multiswitch Questions
Monday, March 6th 2006, 2:09am
Hello all.. new here ;D
Have a few questions regarding the Multiswitch, Aquaero and the Aquastream Control Unit.
1) I have a Seasonic S12 600w PSU and i was wondering will it power all the above on the same rail (each cable has 3 molex connectors and a floppy connector)?
2) If i'm connecting all above together, does that mean i need to connect all 3... as in 1 molex to each hardware?
3) Can/Do i connect both the Multiswitch and Aquaero using internal USB connections.. or di i just plug in the Aquaero?
4) The Aquaero says i can connect up to 6 sensors and 4 fans... does the flow meter act as one sensor so basically i get 5 free?
Cheers for the help... AC noob here
x-stars
Re: Multiswitch Questions
Monday, March 6th 2006, 5:23pm
Quoted from "Carbine"
1) does not matter, because all cable end on the same field inside the nt (only differentiated by voltage), so wire i like you want it to to :)
2) cf 1, but be careful, if you use the aquastream-aquaero-cable (10Pin) you mustn't connect the molex to the controller, if you do so, the controller and the aquaero can be damaged ::)
3) both, you can either connect both to usb or you can connect the auqero to usb and the multiswitch to the aquaero
Regards
Michael
Carbine
Tuesday, March 7th 2006, 1:26am
So for number 2... that means i only use 2 molexes rather than 3?
and what does cf 1 mean?
x-stars
Tuesday, March 7th 2006, 11:08am
confuer 1 - look at point one, wanted to say, that it does not matter which molex you will use ::).
Yes, it means you only need two molex, one for the aquaero and one for the multiswitch. the aquastream is powered trough the connection-cable ;).
Ze@lot
Wednesday, March 8th 2006, 11:56pm
in regards to 4)
as far as im aware the sensors are just for temps, ever water or ambient. iirc cabine you are planning a dual loop system, in which case you would need to connect the 1st flow meter to the flow meter socket & the 2nd to the fan 4 socket. so u will only have 3 fan sockets left to play with. but as the v4.00 aquaero can handle 10watts per channel ( socket ) & a 120mm fan draws 2.16watts, you can have 4 fans to each socket. so even by losing a fan socket you could still run 12 fans, more if you fit a multiswitch.
Carbine
Thursday, March 9th 2006, 2:24am
Thanks for that.. but nope i'm only using 1 flow meter as the other loops 7/16 custom watercooling. Only one loop is Aquacomputer.
And no it isn''t dual loop. Its triple :P
Infiltraitor
Thursday, March 9th 2006, 2:27am
Its triple :P
Darn, that's gotta be one big case unless you're using microbore ;D
Carbine
Friday, March 10th 2006, 12:15am
I'm using a Mountainmods case :)
