• 22.11.2026, 21:55
edboswell
Leaking Problems
Wednesday, December 5th 2007, 1:35am
Hi I have been having leaking problems on the new res. but I think this is 100% down to the fact that the rubber seal that you provide is nearly IMPOSSIBLE to get on.
Are you supposed to glue it on? Or something like this because otherwise you use all the fingers you have on 2 hands to fix it down....let go and the seal just pops off...
Please help me
Thanks
Ed
Top_Nurse
Re: Leaking Problems
Wednesday, December 5th 2007, 5:55am
What reservoir are you talking about?
edboswell
Wednesday, December 5th 2007, 11:55am
The aquabox 5 1/4" black.
edboswell
Wednesday, December 5th 2007, 10:46pm
anyone?...please sorry but I am desperate.
edboswell
Thursday, December 6th 2007, 2:47am
don't worry...sorted it... with superglue (I wasn't orginally going to use it because it might melt it...but this particular glue I found in tesco's could be used on rubber and it has seemed to have done the trick :)
Ed
Infiltraitor
Thursday, December 6th 2007, 3:14pm
When I assembled my aquabox, I had to get one end of the seal in the milled groove and trap it with the faceplate then slowly slide the faceplate along whilst manipulating the seal to keep it in on both sides.
It should've been a test on the old Krypton Factor ;D
Flatline
Saturday, December 8th 2007, 12:23pm
I had similiar problems, the rubber kept slipping off at one side. I solved it by strechting the ring for 45minutes as much as I could. Afterwards I had a couple of minutes to install it until it had reverted to its original state :)
