• 29.11.2026, 09:32
Miyoshi
Aquaero not saving profiles
Sunday, December 23rd 2007, 7:23pm
Hi!
My Aquaero can't seem to be able to save my profiles. I have to manually load my profile in aquasuite every time I restart. I have tried to save data to EEPROM but it doesn't work. I get a shutdown error and my dual leds are blinking. I have tried reflashing via the newest aquasuite and resetted the EEPROM in both the aquasuite and manually by holding the set button for 3 seconds when restarting.
Aquaero is working perfectly only if I manually load my profile in Aquasuite but after restarting it acts very strange. I get a "Shutdown..." message. loading the profile1 or 2 in aquaero doesn't work. Default-profile works though and sets it back like it was when I started the system for the first time. Still after a shutdown the leds blinks red-blue and I get a Shutdown...flow 2 sensor message.
Can anyone please help.
Connections:
Aquaero <- USB -> Motherboard
Aquastream <- USB -> Motherboard
Aquaero <- Aquabus -> Aquastream
One more thing is that Aquaero doesn't recognize my Aquastram XT. It says "Too old or n. avail."
I'm using:
Aquasuite 4.51.00
Aquaero 4.13a firmware
Aquastream 1005 firmware
Tried to flash Firmware 1006 to Aquastream. I get a successful flash according to Aquasuite but it remains a 1005 firmware after restarting...
Rockwool
Re: Aquaero not saving profiles
Sunday, December 30th 2007, 7:36pm
Quoted from "Miyoshi"
Hi!
Connections:
I'm using:
Aquasuite 4.51.00
I dont think that you should connect the aquastream to the MB thru USB. when you do have connectet it with the aquaero
TheRave
Wednesday, January 2nd 2008, 11:48am
Yeah, as far as I am aware you connect the pump EITHER to the motherboard via usb OR to the aquaero via the aquabus, NOT both.
Wednesday, January 2nd 2008, 5:31pm
You can also connect the aquastream to USB and the aquaero.
Miyoshi
Thursday, January 3rd 2008, 3:41pm
ok, so Option 1 and 2 are correct while Option 3 is wrong???
Option 1
Aquaero <- Aquabus -> Aquastream XT
Option 2
Aquastream XT <- USB -> Motherboard
Option 3 is wrong? This is my current connection
Thursday, January 3rd 2008, 3:53pm
Where is the problem?
That's the best combination because so you have ALL controlling and monitoring possibilities.
Miyoshi
Thursday, January 3rd 2008, 8:15pm
Thanks Shoggy. I was just not sure since I was told not to connect the Aquastream via USB while using aquabus.
There is no problem anymore. Everything works fine now. Im using option 3. =)
