• 16.11.2026, 04:04
SNTmods
SNTsystems (English) Aquaero Description Help
Thursday, May 27th 2004, 6:50am
I am in need of some major help, I need a detailed English translation of the Aquaero and all of its characteristics for my online catalog @ http://snt-systems.com. My translating skills from German are poor at best for the product info posted in the shop for the LCD. There are simply too many features for this product. :) I would really appreciate any of your help as I am the only source for AC in the US and for most of the English Speaking World. Thanks!
-Dan
Was an early adopter of Aqua-Computer watercooling in the U.S.
pharao
Re: SNTsystems (English) Aquaero Description Help
Thursday, May 27th 2004, 11:04am
you'll have to give my english a last polish ;D
Quoted
Überwachung von bis zu 6 Temperatursensoren
monitoring of up to 6 temperature - sensors
Quoted
Steuerung und Überwachung von bis zu 4 Lüftern mit individuellen Regelparametern
controlling of up to 4 Fans with individually adjustable Parameters
Quoted
Messung des Durchflusses im Kühlsystem (mit optionalen Durchflusssensor)
measuring the waterflow in the System (optional sensor required)
more when i get back home  ;) ;)
SNTmods
Thursday, May 27th 2004, 11:32am
Thank you for your reply, I will look forward to your future translations.
-Dan
NikoMo
NikoMod
Thursday, May 27th 2004, 12:21pm
Quoted
aquaero Mikroprozessor Lüftersteuerung
Aquaero microprocessor fancontroller
Quoted
Die Steuerzentrale für Ihre Wasserkühlung bietet einen riesigen Funktionsumfang, der keine Wünsche offen läßt. Der Begriff der "Lüftersteuerung" ist hier absolutes understatement.
the commandcenter for your watercooling offers a lot of working options, which lets no wishes open. the name of "fancontroller" is simply understatement
Quoted
Die Funktionen im Überblick:
the options in an overview:
Quoted
- Überwachung von bis zu 6 Temperatursensoren
Quoted
- Steuerung und Überwachung von bis zu 4 Lüftern mit individuellen Regelparametern
controlling and monitoring of up to 4 Fans with individually adjustable Parameters
Quoted
- Messung des Durchflusses im Kühlsystem (mit optionalen Durchflusssensor)
measuring of waterflow in the System (optional sensor required)
Quoted
- Soft-TCS, in Hardware realisierte Abschaltung des ATX-Netzteiles bei Überschreitung vorprogrammierter Parameter (mit optionalem Kabelsatz)
soft-tcs, in hardware realised off-switching of the atx-psu when reaching of programmed parameters (optional kableset required)
Quoted
- integrierte Zeitschaltuhr (mit optionalem Kabelsatz)
internal timer (with optinal kableset)
Quoted
- Ausgang für ein Multi-Color-Beleuchtungsmodul oder 2 Alarm-Schaltausgänge
connector for multi-color-lightmodule (optinal) or 2 alarm-switchconnectors
Quoted
- Inverses Display mit wahlweise grüner oder blauer Schrift auf dunklem Hintergrund
inverted display with choice of green or blue text on dark background
Quoted
- Regelbare Displayhelligkeit, regelbarer Kontrast über das Menü
adjustalbe displaybrightness, adjustalbe contrast by menu
Quoted
- Integrierte Diagnosefunktionen für die quastream-Pumpe
integrated diagnosefunction for the aquastream-pump
Quoted
- aquabus - Der AC-Erweiterungsbus lässt (fast) unendliche Möglichkeiten offen und benötigt nur 3 Leitungen
aquabus - the AC-extensionbus offers (nearly) endless options and requires only 3 lines
Quoted
- Anschlussmöglichkeit für bis zu vier Achtkanal-Schaltkarten, die auch als Bargraph konfiguriert werden können.
connectingpossibility for up to 4 eightchannel-switchcards, which might be configured as a bargraph
Quoted
- USB-Verbindung zum Rechner, alle Einstellungen lassen sich über Software steuern und anzeigen
USB-connection to the computer, anny settings might be controlled and displayed by software
Quoted
- Open Source Projekt für die PC-Software, Bereitstellung von Datenblättern und Referenzsoftware
open source project for the pc-software, offering of datasheets and referencesoftware
Quoted
- Edelstahlgehäuse, Beschriftungen lasergraviert
stainless steelchassis, lasermade text
Quoted
- Taster in Metallausführung
buttons made by metall
Quoted
- Firmwareupdate per USB möglich
firmwareupdate by USB possible
[hr]
Quoted
aquaero 3.07 mit LC-Display blau/weiß
aquaero 3.07 with LC-Diplay blue/white
Quoted
Lieferumfang:
sold:
Quoted
- aquaero Controller montiert in 5 1/4" Einbaurahmen
aquaero controller mounted in 5,25" frame
Quoted
- Gebürstete Edelstahl-Frontblende (montiert)
stainless steel front with brushed appearance
Quoted
- LC-Display mit weisser Schrift auf blauem Hintergrund
LC-Display with white text on blue background
Quoted
- zwei Temperatursensoren 40 cm
two tempsensors 15.7inch
Quoted
- zwei Temperatursensoren 70 cm
two tempsensors 27.5inch
Quoted
- internes USB-Anschlusskabel
internal usb-connection-cable
Quoted
- Anleitung
manual
Quoted
ACHTUNG: Lieferbar ab Mitte Juni.
attention: available from middle of june
@ hobbes
please edit, if something is bad explained
bitte editier das , wenn ich etwas falsch/undeutlich ausgedrückt habe.
@ SNT
i hope, this is helpfull enough for you. if not, just ask
certhas
Thursday, May 27th 2004, 12:27pm
- soft-tcs, hardware based shutdown function of the psu if predefined parameters are overstep (requiers optional cable)
- integrated timer (needs optional cable)
- output for a multicolour-lighting module or 2 alarm-outputs
- inverse display, choosable black display with yellow font or blue display with white font
- adjustable display brightness, adjustable contrast both tuneable via menue
- integrated diagnostic function for the aquastream pump
- aquabus - the AC-upgradebus offers almost infinite possibilities, requiers three wires
- possibility to connect up to 4 8-channel card-modules who can also be configured as bargraph.
- USB-connection to the pc, all settings can be controlled via software
- open source project for the pc-software, supply of datasheets and reference software
- stainless steel case, labelling laserengraved
- push-button in steel design
- firmware via usb flashable
SNTmods
Monday, May 31st 2004, 12:09pm
Can someone explain what the Soft TCS is?
Im also going to start letting the English speaking community know that the support forums here are very helpful so expect more english threads in the future. :)
-Dan
TaK47
iRe: SNTsystems (English) Aquaero Description Help
Monday, May 31st 2004, 12:36pm
TCS = Thermo Control System!
This will shut your system down if it's too hot!!
greetz TaK47
KingofBohmte
Monday, May 31st 2004, 12:49pm
  • Soft TCS means that your computer will shut down by the aquaero when certain parameters are reached (e.g. very high water temperature) -> software controlled
  • Instead "normal" TCS is installed between the PSU and your Mainboard. It shuts down your computer by cancelling power when the cooling block becomes too hot -> hardware controlled (see http://www.aqua-computer.de/content/ueberwachung.htm)
SNTmods
Monday, May 31st 2004, 1:54pm
Is the TCS just controlled by a water temperature probe installed in the Aquatube as described on the site?
-Dan
NikoMo
NikoMod
Monday, May 31st 2004, 3:23pm
AC offers two kind of TCS
  • a hardware-based version
    which comes between the psu and the mainboard.
    the thermal-sensor should be mounted at the cuplex (normal, evo or pro). when a spezial temperature is reached, the sensor shuts down the computer.
  • a software-based version
    it is included in the aquaero. you can observe any temp-sensor you want(e.g. water, cpu). when this sensor measures a self-defined temperature, the system will be shuten down.
avalon.one
Monday, May 31st 2004, 3:33pm
shut down ;) (shut ist ein unregelmäßiges verb)
NikoMo
NikoMod
Monday, May 31st 2004, 5:18pm
Quoted from "avalon.one"
dat is mir wurscht :P ;D
selbst wenns ein gestaffeltes oder gewickeltes verb wäre.
aber da du den rechtschreibfelher gefunden hast, bekommst du von mir ne wakü zsb
SNTmods
Friday, June 11th 2004, 2:34pm
What kind of lighting effects can be contolled? Also, what can be done using the Aquabus? Please list examples if possible.
-Dan
SNTmods
Friday, June 11th 2004, 2:41pm
[glow=red,2,300]possibility to connect up to 4 8-channel card-modules who can also be configured as bargraph[/glow]
What is this capable of? I clearly dont understand.
-Dan
NikoMo
NikoMod
Friday, June 11th 2004, 2:49pm
Quoted from "SNTmods"
-Dan
soon (round about 3 weeks) there will be an additional module for the aquabus. the aquabus multiswitch is able to control up to 8 12V-channels where you can mount cold cathodes or normal fans or something else that needs 12V to work proper.
you can turn on or off these eight channels as you wish
edit:
for working as a bargraph you have to configure the software. (e.g one cathode wil work at 35°C, 3 at 45°C, 5 at 55°C and so on) when you use differentcolored cathodes you can show how warm your computer is.
you can also use normal LEDs but cathodes.
or simply an fan that will start working at a selfdefined temperature
