• 12.11.2026, 19:39
alex75
OCTO + D5 NEXT
Saturday, September 12th 2020, 6:11pm
Hello
i have an Octo and a D5 NEXT pump, in Aquasuite can't choose the D5 water temp as a data source for controlling fans.. is it possible ?
Thanks
alex75
RE: OCTO + D5 NEXT
Sunday, September 13th 2020, 12:12pm
Hello
Thanks
Ok i figured it out..
Cheers
lazer-hawkuk
Monday, January 8th 2024, 7:43pm
i know it was a long time ago but what did you do i need todo the same.
thanks
nevermind found it you you goto sensors and click soft sensor 1 then choose the source as d5 next temp , so now i can control the octo with a fan curve
This post has been edited 1 times, last edit by "lazer-hawkuk" (Jan 8th 2024, 9:00pm)
