• 22.11.2026, 22:05
cckevinc
Aquastream XT fan port power
mercredi 15 juillet 2009, 09:39
Hi there,
Does anybody know the current output of the fan port of the Aquastream XT? So that I can estimate how many fans can be connected to there.
Thanks! :thumbsup:
Lumi
mercredi 15 juillet 2009, 12:21
The maximum output is 5W (12V * 0,4A)
One or two fans are possible, as long as you know the real consumption.
mercredi 15 juillet 2009, 20:28
With the latest firmware you can reach around 5 - 6W. It can be also used with three fans but that will depend on the used fans. If you want to run three, look after fans with a low current consumption.
olatronic
samedi 26 septembre 2009, 12:27
I have 3x 1.8w fans I want to connect to my XT Ultra... Would that be ok then?
I was going to wire them in parallel and use the rpm signal from only one of the fans?
Thanks, it's my first system :D
dimanche 27 septembre 2009, 13:07
Pretty sure it will not work if you don't want to run them at 100%.
olatronic
dimanche 27 septembre 2009, 18:56
So what's the best method if you want to control all 3 fans through aquasuite? Buy an aquaero?
olatronic
mardi 20 octobre 2009, 21:05
F*** it, I bought one anyway :P
Top_Nurse
mardi 20 octobre 2009, 23:17
You will love the capability!
Another possibility would be to slap a heat sink on the offending mosfet, but then you would have to mod the cover or leave it off.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Top_Nurse" (20 octobre 2009, 23:54)
