• 03.10.2026, 07:13
mccardle05
32 bit v 64 bit vista?
jeudi 10 décembre 2009, 09:01
'm building my first rig (I asked a question on this earlier) and automatically ordered 32 bit vista HP for the OS when it came to it. I was checking other components this morning and noticed the mobo I ordered is 64 bit compatible, but as I'm only working with 2 gigs ddr2 memory I thought nothing of it.
disability is a curse but I being a disabled know that disability aids could make it easier!
headfrag
jeudi 10 décembre 2009, 11:32
If you're not planning to use more than those 2Gig RAM you should be fine with your choice. If you decide to switch to a 64bit OS you should get Windows 7. Win 7 is generally speaking more mature than Vista and the future support esp. with drivers will be better.
