• 14.10.2026, 06:13
slotrod
Custome black anodized plate for filter PROJECT CARBON
vendredi 8 octobre 2010, 07:21
I;m posting this here since i figure the most interest in this would be here. from states so i hope this translates correctly
I'm in the process of building my Project CARBON build and I'm having 2 of these made for my 800D one on top and one on inside shelf. hope you like and will post finished ones when done.
Uploaded with ImageShack.us
Ce message a été modifié 1 fois. Dernière modification effectuée par "slotrod" (16 octobre 2010, 20:13)
slotrod
vendredi 8 octobre 2010, 07:28
My BUILD LOG
CASE
CORSAIR 800D BLACK
Mountain MODS
Tripple 120 panel 9x24 blank panel 18x24 blank panel
Back plate & I/O Insert both Anodized Black
MNPCTECH
360 degree 3x120 2x120 (2) 120 anodized black fan grills
Anodized black Vandal Switch Panel
[b]Anodized black custom plate for Aqua Computer Filter X2
Anodized black custom plate for Crystal Fontz LCD with project name.
ODDS & ENDS
3M DI-NOC CARBON FIBER film Black
Black Acustical pad
Black 1/16 round hole Modders Mesh
CONTROL
Aquario 4.0 with power adjust with black face plate
Aquacomputer Power adjust 2 (X3) with Black face plate
SYSTEM
EVGA X58 SLI LE BOARD
Proccsor undecided
RAM Corsair Dominator GT 12G of something
Storage SSD undecided
GPU Either 465X2 or 470x2
LOOP1
Swifttech MPC350 12v ( x2)
XSPC Dual Top
XSPC RX360 Rad
XSPC RASA CPU Cooler Black
Primochill 7/16 X5/8 Tubing clear
Aqua Filter
Aqua Flow Sensor
Aqua Ram Plex (X2)
Aqua nickel plated res with Black 5 1/2 bay Panel
M.I.P.S. Mother board Blocks Black/ Nickel
Bitspower Fittings
LOOP2
Swifttech MPC350 12v (X2)
XSPC Dual Top
XSPC RX240 rad
Aqua Filter
Aqua Flow Sensor
Aqua Twin Plex
Aqua 465/470 nickel GPU Blocks (x2) back plates If I can find ones to fit
Danger Den RES
Primochill 7/16 X 5/8 Tubing Clear
[/b]
[b]Extra Stuff
MDPC SLEEVE BlacK & Purple for wires
Black 5/8 sleeve for tubing
Srews Snap Caps Rivets Clamps Tools
Some purple LED's for mood lighting in pump tops and res
IF I missed anything it wont fit
[/b]
Ce message a été modifié 1 fois. Dernière modification effectuée par "slotrod" (8 octobre 2010, 07:34)
slotrod
lundi 11 octobre 2010, 05:41
finished product now off to be anodized :D
Sappibaer
lundi 11 octobre 2010, 08:14
WOW
That looks very nice :thumbup:
Out of Style, but it's Retro!
Cryma
lundi 11 octobre 2010, 13:48
Hello
First I would say you that it looks very nice and i´m thinking to that i understand the function but can you can explain the specificant use of this for me ?
...lauter spinner ;)(wehe, das nimmt jemand in seine sig ;))dino
slotrod
lundi 11 octobre 2010, 14:55
HI
The filter is to take out any dirt or contaminates out of your water coolant as to not block or restrict the flow of your coolant. The plate is because it looks cool
I can also use this as a fillport on top of the case if i want to.
Ce message a été modifié 1 fois. Dernière modification effectuée par "slotrod" (11 octobre 2010, 14:58)
Cryma
lundi 11 octobre 2010, 17:01
oh that´s an good idea :) you´ve made this very proffessional .. respect :D
Morpheuzz
lundi 11 octobre 2010, 17:15
nice work, ehm you made something else on youre case?
or you built it firtst.
slotrod
lundi 11 octobre 2010, 20:33
I have this print of the next plate to be made this will mount on the front bezel for LCD screen.
also some pictures of the build in progress
Ce message a été modifié 1 fois. Dernière modification effectuée par "slotrod" (11 octobre 2010, 20:37)
slotrod
lundi 11 octobre 2010, 20:36
This is back door of 800d covered in 3M DI-NOC Carbon Fiber Film
Cryma
mardi 12 octobre 2010, 14:41
have u two pumps in your sysstem ? on the one picture it looks so a bit
Morpheuzz
mardi 12 octobre 2010, 18:15
i think he hast 4 pumps bundled in 2 and 2 ... with a XSPC dual top for laing ddc.
slotrod
mardi 12 octobre 2010, 20:02
Thats correct 2x2 pumps 2 pumps on two duel tops.
Morpheuzz
mardi 12 octobre 2010, 21:52
hehe, Im great. :)
ehm you juse two reservoirs or only one?
hmmm...
the hole pc with carbon, hmmm good idea. :)
slotrod
mercredi 13 octobre 2010, 00:54
:) If you look above you will find the second one. Its the Aqua nickel plated that will be mounted in 2 5 1/2 bays on front bezel.
Only the 2 doors , back panel and motherboard tray will be covered with Carbon. As of now the rest will be high gloss black
Cryma
mercredi 13 octobre 2010, 12:46
why do you use 4 laings ??? is your watercooled system so extensive that you need 4 laings ? ?(
slotrod
mercredi 13 octobre 2010, 16:16
I know it seems a bit redundant to have two pumps.
First moving water stays cooler. I also like volume for better cooling. But the main reason is safety. If I lose a pump I will not fry my system the second pump will be enough to cover the system. ALSO IT LOOKS COOL 8)
slotrod
mercredi 20 octobre 2010, 19:58
motherboard started
slotrod
jeudi 21 octobre 2010, 20:04
slotrod
vendredi 22 octobre 2010, 20:46
Discussions similaires
