• 14.11.2026, 16:29
barfly
farbwerk a6 q
vendredi 27 novembre 2015, 23:55
im getting different thermal probe reading from my farbwerk and aaquaero 6 even tho both thermals are located side by side in the same place
can i tie one farbwerk thermal into a aquaero thermal without any issues?
using offsets wont help because the 2 thermals change temps differently
tia
RE: farbwerk a6 q
samedi 28 novembre 2015, 23:35
tia
If you have a temperature sensor plugged into a farbwerk temperature port, then yes, you can move it to one of the aquaero 6 temperature ports.
Since you have both thermals in the same location, you may want to make a virtual sensor that gives the average of the two... or the highest.
barfly
samedi 28 novembre 2015, 23:58
moving the farbwerk thermal to the a6 would do no good since the a6 wont read the farbwerk thermals
ill look into the virtual but with no docs,un-necessary time will be wasted figuring it out.
barfly
dimanche 29 novembre 2015, 16:01
sebastian,ive read the .pdf but it doesn't seem to cover what i need.
basically when im in my farbwerk i only have aida sensors available,when in in the a6 i don't see farbwerk thermals,unless their called poweradjust and those dont coincide with farbwerk temps.
dimanche 29 novembre 2015, 17:38
this is ok. when you need other temperatures you have to connect a sensor directly to the farbwerk.
barfly
dimanche 29 novembre 2015, 20:18
when im running a fan curve in the a6 i need to use the same sensor in the farbwerk so the led transition will be the same as my fan profile,the farbwerk needs to see the a6 sensors which it dont as it only sees aida64
lundi 30 novembre 2015, 07:11
