• 29.11.2026, 06:56
jeudi 12 avril 2018, 01:40
Dear all
My device update software and firmware after
Not connected MPS
please help me
Thanks All
alexchan0829 has attached the following files:
MPS appears connected by aquabus.
MPS appears not connected by USB.
Are you using a USB hub?
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (12 avril 2018, 01:42)
alexchan0829
jeudi 12 avril 2018, 16:38
Yes I have used USB hub
vendredi 13 avril 2018, 00:14
Sometimes a USB hub introduces a problem.
It may be useful to move one of the MPS unit USB cables from the hub and connect it direct to a motherboard USB port to see if it shows that way.
alexchan0829
vendredi 13 avril 2018, 14:14
感謝您的幫助和回复
vendredi 13 avril 2018, 14:29
感謝您的幫助和回复
"Thanks for your help and reply"
You are welcome, hope it helped.
annihilation
vendredi 11 mai 2018, 14:58
I have one of these flow sensors: https://shop.aquacomputer.de/product_inf…roducts_id=2294
How do I go about getting this updated? It is currently showing up under Aquabus but says "The device has no USB connection to is not recognized by the system" and then Remove device from aquasuite.
Any ideas?
GTXJackBauer
vendredi 11 mai 2018, 16:20
Any ideas?
There is a proprietary cable that you need to purchase since it's sold separately (unfortunately) and plug it into the Flow Header behind the AQ. Once you've done that, you can check and is if it's working under the Aquaero tab ---> Sensors tab ---> Flow Sensors. Once there, you should be able to choose your flow meter.
This particular flow meter doesn't need any firmware updates. It's basically a plug n play flow meter. That's not to be said about the other flow meters they sell that need a Aquabus or USB connection which then do need to be updated via firmware.
Ce message a été modifié 1 fois. Dernière modification effectuée par "GTXJackBauer" (11 mai 2018, 16:22)
annihilation
vendredi 11 mai 2018, 16:27
Interesting. It stopped working since the update which is why I was asking. I will check the connections.
lundi 14 mai 2018, 15:48
Any ideas?
Are you sure the linked one is really your device?
The device in your link has no aquabus and no firmware. It cannot be updated.
Ce message a été modifié 1 fois. Dernière modification effectuée par "wpuser" (14 mai 2018, 15:49)
CoAff
jeudi 24 mai 2018, 02:08
Any ideas?
The linked device uses this: https://shop.aquacomputer.de/product_inf…nu67405to0tgogk to communicate.
nhorn1983
jeudi 7 juin 2018, 13:22
is it possible to get an update on the software on the kryos kuplex block. i just installed my ryzen 2700x on an asus strix x470 gaming-f last night and the temp sensors are showing close to 100c this has to be a software bug as it was reading correctly the other day with an asrock x370 board. thank you
Ce message a été modifié 1 fois. Dernière modification effectuée par "nhorn1983" (7 juin 2018, 17:30)
jeudi 14 juin 2018, 15:03
You can try to reset the device back to the factory defaults but I doubt that this is a software related problem. It is much more likely that the temperature sensor got damaged by installing the CPU again. The sensor is very sensitive to pressure and will show weird values when it gets damaged.
What is the exact variant of the block that you have? Maybe you can exchange it yourself.
Discussions similaires
