• 05.10.2026, 11:00
GTXJackBauer
HUBBY7
mardi 2 juillet 2019, 01:54
If I jumped two HUBBY7's together, do I still need to connect both of their SATA Powers? Ran out of USB headers so I have another HUBBY7 on the way and was wondering how to go about this.
Can you also have the USB selected up top on the jumper with a SATA Power connected or does it have to be jumped to SATA in order to use the SATA Power header? What if USB is selected and SATA Power is given, will that cause an issue?
Also, do I chain from pinout #1 on HUBBY7 to the other HUBBY7's pinout #1?
Ce message a été modifié 1 fois. Dernière modification effectuée par "GTXJackBauer" (2 juillet 2019, 01:56)
mardi 2 juillet 2019, 04:47
Something niggles in the back of my head about issues if you chain a second USB hub from a first USB hub.
But since you have it ordered, Il'd say try it.
What I would do is take one of the USB OUTs from the first hub and run it to the USB IN of the second hub.
Then set the jumper for the primary hub to USB, and the jumper for the secondary hub to SATA, with a SATA connection.
This way the second hub will not be drawing power from, and possibly overloading the motherboard port.
GTXJackBauer
mardi 2 juillet 2019, 23:48
I hope testing this out, won't fry my stuff. I'm kinda nervous to try. lol
