• 30.11.2026, 22:30
JIT
Aqua Computer Service hold CPU high randomly and crash with bluescreen.
mardi 6 août 2019, 13:08
windows 10 64bit pro.
first,
from the old aquasuite(2017and 2018 version) what I used until today,
Aqua Computer Service randomly hanging CPU resource too high.
CPU temperature being up to 50~60 degree C, from normal 40~45 degree C at IDLE.
it could be solved when I manually restart the service.
second,
I updated aquasuite to X4 today and I remove previous installed service because of reason what I wrote above,
after remove by windows console command, re-install Aqua Computer Service from aquasuite program.
few minutes after the install, suddenly windows bluescreen crash happen.
it only said about IRQL_NOT_LESS_OR_EQUAL.
I got minidump file so analyze by winDBG program.
here is the analyzed result of minidmp file.
in analyzed result, I found PROCESS_NAME: AquaComputerSe
so, this BSOD crash from aquacomputer service
* Bugcheck Analysis *
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 00000000000000b8, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff801342fa6fa, address which referenced memory
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.Sec
Value: 4
Key : Analysis.Elapsed.Sec
Value: 4
Key : Analysis.Memory.CommitPeak.Mb
Value: 70
Key : Dump.Attributes.InsufficientDumpfileSize
Value: 1
PROCESSES_ANALYSIS: 1
SERVICE_ANALYSIS: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10.0.18362.267 (WinBuild.160101.0800)
DUMP_FILE_ATTRIBUTES: 0xc
Insufficient Dumpfile Size
Kernel Generated Triage Dump
DUMP_TYPE: 2
BUGCHECK_P1: b8
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff801342fa6fa
READ_ADDRESS: fffff801347713b8: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
00000000000000b8
CURRENT_IRQL: 2
FAULTING_IP:
nt!MiUnlockPageTableInternal+a
fffff801`342fa6fa 0fb691b8000000 movzx edx,byte ptr [rcx+0B8h]
CPU_COUNT: 10
CPU_MHZ: bb8
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 3f
CPU_STEPPING: 2
CPU_MICROCODE: 6,3f,2,0 (F,M,S,R) SIG: 43'00000000 (cache) 43'00000000 (init)
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
ANALYSIS_SESSION_HOST: JIT-CAN
ANALYSIS_SESSION_TIME: 08-06-2019 19:53:54.0219
ANALYSIS_VERSION: 10.0.18914.1001 amd64fre
TRAP_FRAME: ffff8484dabe93f0 -- (.trap 0xffff8484dabe93f0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=ffffb88000000000 rbx=0000000000000000 rcx=0000000000000000
rdx=ffffb8dc40991438 rsi=0000000000000000 rdi=0000000000000000
rip=fffff801342fa6fa rsp=ffff8484dabe9588 rbp=ffff8484dabe96c0
r8=0000000000000000 r9=ffffb8dc40991438 r10=0000000000000000
r11=0000007ffffffff8 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz ac po nc
nt!MiUnlockPageTableInternal+0xa:
fffff801`342fa6fa 0fb691b8000000 movzx edx,byte ptr [rcx+0B8h] ds:00000000`000000b8=??
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff801343d1ae9 to fffff801343bfcc0
STACK_TEXT:
ffff8484`dabe92a8 fffff801`343d1ae9 : 00000000`0000000a 00000000`000000b8 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
ffff8484`dabe92b0 fffff801`343cde2b : ffffb8dc`6e204000 ffff8484`dabe96d0 fffff801`342accf1 ffff8484`dabe96d0 : nt!KiBugCheckDispatch+0x69
ffff8484`dabe93f0 fffff801`342fa6fa : 00000000`00000000 00000003`35072451 000000f6`90610000 ffffd50c`975ad580 : nt!KiPageFault+0x46b
ffff8484`dabe9588 fffff801`3426f106 : ffff8484`dabe96d0 00000264`00000002 fffff801`00000001 ffffb8dc`00000000 : nt!MiUnlockPageTableInternal+0xa
ffff8484`dabe95c8 00000000`00000000 : ffff8484`dabe99e0 ffff8484`dabe9b80 fffff801`347d65d2 00000000`00000000 : nt!MiQueryAddressState+0xc96
THREAD_SHA1_HASH_MOD_FUNC: 6fbecbdf71cc502c076807292ade73cd8b2f4df3
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 3a2e2381b35efd32434153bbf61b0d444af67e80
THREAD_SHA1_HASH_MOD: f08ac56120cad14894587db086f77ce277bfae84
FOLLOWUP_IP:
FAULT_INSTR_CODE: b891b60f
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!MiUnlockPageTableInternal+a
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 74da155a
IMAGE_VERSION: 10.0.18362.267
STACK_COMMAND: .thread ; .cxr ; kb
IMAGE_NAME: memory_corruption
BUCKET_ID_FUNC_OFFSET: a
FAILURE_BUCKET_ID: AV_nt!MiUnlockPageTableInternal
PRIMARY_PROBLEM_CLASS: AV_nt!MiUnlockPageTableInternal
TARGET_TIME: 2019-08-06T10:01:31.000Z
OSBUILD: 18362
OSSERVICEPACK: 267
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2032-02-15 18:16:10
BUILDDATESTAMP_STR: 160101.0800
BUILDLAB_STR: WinBuild
BUILDOSVER_STR: 10.0.18362.267
ANALYSIS_SESSION_ELAPSED_TIME: 126f
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:av_nt!miunlockpagetableinternal
FAILURE_ID_HASH: {fdd0de49-46dd-5792-449c-2e88bc15a9b1}
Followup: MachineOwner
Ce message a été modifié 2 fois. Dernière modification effectuée par "JIT" (6 août 2019, 15:18)
LocutusH
vendredi 30 août 2019, 14:57
Do you have a new Ryzen system? I saw posts, that hardware monitoring programs can pull the processor unnecessarily from idle state. That might be the reason for your cpu temp.
samedi 31 août 2019, 08:27
have you other monitoring software active?
When you dont need aqua computer monitoring, deactivate the functions that you do not need (aquasuite->service)
