• 02.11.2026, 13:43
knacker
D5 next- compatible on Corsair XD5 res
samedi 21 septembre 2019, 19:52
Can anyone tell me if the D5 next wold connect ok with the Corsair XD5 pump/res combo as client wants to use one with her AE6 but the standard pump doesnt play well with aquasuite
thx
Hufeisen
lundi 23 septembre 2019, 13:57
The reason is that the standard D5 pump PWM Signal does not comply with the Aquaero PWM Specifications.
To fix this, you need to modify the Pump Connector and add some resistors.
Read this post how to do it: https://www.overclock.net/forum/61-water…ml#post22946282
knacker
lundi 23 septembre 2019, 15:30
that's true- thanks for that but not the question I was asking. :D
Edit: should have asked if the D5 next is a standard size D5 pump :D
Ce message a été modifié 1 fois. Dernière modification effectuée par "knacker" (23 septembre 2019, 16:32)
Hufeisen
lundi 23 septembre 2019, 23:01
Yes, the D5 next is a standard size D5 pump.
The problem can be the plugable electronic unit with the display.
I dont know if the display of the D5 next will collide with the reservoir or not.
Ce message a été modifié 3 fois. Dernière modification effectuée par "Hufeisen" (24 septembre 2019, 00:16)
knacker
mardi 24 septembre 2019, 09:34
thanks Hufeisen
thats the answer I was looking for- just need to check on the depth of the pump to see if the connection will clear the fittings
