• 13.11.2026, 19:28
sultan.of.swing
Aquacomputer d5 pwm
samedi 18 avril 2020, 22:42
Ok so I have a very strange issue I can't figure out.
I have a Aquacomputer D5 PWM pump that I have had connected to an Aquaero 6XT fan header for a while without issues.
I did a drain and refill and now I can no longer get the pump to go over 1830 RPM no matter which header I use on my Aquaero. Unplugging the PWM Wire from the PWM header on the Aquaero it does not speed up like most PWM d5's do.
Now here is the kicker, If I plug it into my motherboard header I can control it there and it will go to 4800rpm exactly as it is supposed to do.
Here is another kicker, I can plug in a different D5 into the header on the Aquaero and that pump works fine on that header.
Slightly confused here.
sultan.of.swing
dimanche 26 avril 2020, 17:16
Still not sure what is wrong with this thing.
ajeet21
lundi 11 mai 2020, 19:34
no one has the answer? I still have the same problem and it makes me nearly crazy
mardi 12 mai 2020, 07:28
Looks like an defect. Please contact the support.
sultan.of.swing
mercredi 13 mai 2020, 21:39
I bought the pump from Titan Rig here in the US. Unfortunately when I contacted them they told me they had no stock.
My system has 3 D5’s in series and is a big hassle to pull apart.
I’ll see what support might say though when I get a chance.
