• 01.10.2026, 07:22
WinstonWoof
Aquasuite X.41 Temp Sensor Misreporting
samedi 24 juillet 2021, 11:32
SInce upgarding to X.41 as simple calculation steps to display Delta temps are returning negative values.
Actually looking at it It appears to be be misreading the Ambient Temp as 100
NB I still have X.39 on the other W10 install on this same PC and that is reporting the ambient temp correctly so not hardware issue
WinstonWoof a envoyé le fichier suivant :
  • virtualsensor.JPG (60,41 kB - téléchargé 69 fois - Dernier téléchargement : Aujourd’hui, 00:11)
WinstonWoof
samedi 24 juillet 2021, 11:34
Just noted that according to ASX.41 firmware also requires update.
Will try that and report back
  • Firmware.JPG (75,9 kB - téléchargé 76 fois - Dernier téléchargement : Hier, 15:30)
WinstonWoof
samedi 24 juillet 2021, 11:43
Upgrading the firmware has resolved the temp sensor reading issue in X.41 although, as anticipated, the other W10 install running X.39 is now reading ambient as 100c instead.
Little tip for the developers .
If a version of the software is firmware dependent then during software install you should be prompted to also upgrade the firmware/carry out firmware upgrade as part of software upgrade.
(And please don't tell me that its hidden in a changelog that the firmware has to also be upgraded as that is not a User Friendly way to do it)
WinstonWoof
samedi 24 juillet 2021, 11:52
On the Changelog front it (English and German) hasnt been updated since Jan 2021 and has X.30 as the latest version
aquasuite changelog - English
Ce message a été modifié 1 fois. Dernière modification effectuée par "WinstonWoof" (24 juillet 2021, 11:53)
samedi 24 juillet 2021, 12:26
You found a discontinued thread.
Here is a link to the current CHANGELOG, which is linked on the SOFTWARE DOWNLOAD page.
WinstonWoof
samedi 24 juillet 2021, 12:53
Ta
Still needs tidying up though.
The thread I found was the most recent in the sub forum immediately above this one
  • Capture.JPG (66,73 kB - téléchargé 96 fois - Dernier téléchargement : Hier, 18:28)
WinstonWoof
samedi 24 juillet 2021, 12:54
and also not its not hidden in what is currently a 27 page (& expanding thread)
The changelog I found is easy to digest and find as it cant be commented on unlike the (helpful) link you provided
