• 06.11.2026, 16:32
Dippy
Aquasuite intermittent issue
jeudi 14 octobre 2021, 11:51
I have been using High Flow Next and OCTO with Aquasuite for a while now and they work well together. Unfortunately it seems that I have an intermittent issue between Aquasuite and my Gigabyte Aorus X570 Master motherboard. Occasionally after startup I will see that Aquasuite is reporting "---" for some of the sensors. They are always sensors from the ITE IT8688E chip. A reboot has always solved the problem, however I have now seen that whilst Aquasuite is not reading the measurements, 3rd party application HWiNFO64 does. This implies that it is not a motherboard issue but an Aquasuite one. I just terminated Aquasuite and the service. When I restarted it I got the message that the service had not started and I needed to run Aquasuite as administrator in order to do so. Once I did that and started the service all measurements were restored. Is this a known issue when not running Aquasuite in administrator mode?
WinstonWoof
RE: Aquasuite intermittent issue
dimanche 17 octobre 2021, 12:08
There's no need to restart Aquasuite in Admin mode to restart the service.
If aquasuite gets glitchy for any reason (which is rarely for me) I simply close it, then use Windows Services snapin (Win+R, services.msc , click OK) , stop the Aquasuite service,Start the Aquasuite service and then reopen Aquasuite normally
WinstonWoof
mardi 19 octobre 2021, 09:41
footnote :
Forgot to add.
What I've got is a .bat file on the desktop with the following lines in. Then I can just right click and run as administrator whenever I need to restart (usually after waking from sleep) the Aquacomputer services.
@echo off
net stop "Aqua Computer Service"
net start "Aqua Computer Service"
