• 29.11.2026, 03:00
psychotik2k3
[solved] Highflow next through Quadro indicates 16X the real flow
vendredi 29 juillet 2022, 17:00
Hi i have a high flow next that i plugged both on usb and a flow input of a quadro (my quadro is plugged both in usb and aquabus to an aquaero 5)
on aquasuite while the hgighflow indicates 106l/h on the quadro (and then on the aquaero) it indicates 1775l/h
on the quadro when i go to the sensor i cannot change to the correct value, i have the choice for older aquacomputer flowmeters not the next.
i checked on the doc again and there is no limitation about that.
Ce message a été modifié 1 fois. Dernière modification effectuée par "psychotik2k3" (30 juillet 2022, 00:17)
vendredi 29 juillet 2022, 17:12
Please check if you have selected the right option.
psychotik2k3
samedi 30 juillet 2022, 00:16
thanks that was that.
samedi 30 juillet 2022, 19:22
I am confused. How can you have a Quadro connected to USB and to an Aquaero via Aquabus? I thought if you connected a Quadro or an Octo to an Aquaero via Aquabus, the fan controller becomes a slave to the Aquaero and would not longer appear as a separate device in Aquasuite. Is it OK to connect a Quadro or Octo with USB and to an Aquaero via Aquabus at the same time?
Jacob
RE: [solved] Highflow next through Quadro indicates 16X the real flow
dimanche 31 juillet 2022, 12:01
Citation de "'that.[/quote"
You don't need to connect high flow to aquaero with aquabus that would result in a detection error,
Use aquaero's information pages to select the correct signal high flow number :)
Bartdude
lundi 1 août 2022, 06:25
Yes you can connect both at the same time
lundi 1 août 2022, 19:36
OK thank you. I thought that the Aquabus connection and the USB connection were exclusive to each other.
lundi 1 août 2022, 20:26
If memory serves, having the octo/quadro aquabus connected to the aquaero, does slave the pwm ports to the aquaero. Doing so essentially excludes the fan controllers from the octo/quadro for a total of 4 controllers (aquaero only), instead of 12/8 possible controllers. (octo 8 + aquaero 4 or quadro 4 + aquaero 4)
