• 02.10.2026, 10:08
helios637
API to access RGBpx externally?
mercredi 29 mars 2023, 18:03
Hello,
I want to adjust the brightness of RGBpx based on an ambient light sensor running on a Pi. I don't care whether I set up the automation in Aquasuite or in a Python script on the Pi
Is what I want to do possible?
jeudi 30 mars 2023, 07:23
This is not provided or possible.
Remayz
jeudi 30 mars 2023, 17:02
I know that may sound absolutely terrifying to a Pi or Arduino user but... maybe just using a LDR and maybeee a resistor (playing with the resistance values) to mimic a 10k thermistor, and plugging that to a temperature sensor input of whatever controller you use may be enough? ^^
All controllers have what's basically a resistance meter that can vary any parameter of the lighting. What you want to do with a Pi could very well be achieved with discrete components.
I have a couple of light sensitive resistors from an arduino kit, and in ambient light their resistance vary between 10 and 3kOhms when i place my hand over it. that's not far from what a 10k NTC does with temperature.
And no code needed, Aquasuite can vary effect brightness with a sensor input.
Discussions similaires
