• 30.09.2026, 11:42
klara
Does quadro or octo preserve curve controll before Windows boot?
jeudi 27 avril 2023, 18:23
If I once setup fan curve control depending temperature, does this still work without Windows boot, for instance, on startup of my PC?
If this works, does it work with temperature from software sensor?
For instance, I have high flow next and I can setup curve control using high flow next's temperature using software sensor without any temperature sensor connection on Quadro/Octo.
Can I expect this work properly without Windows/aquasuite once setup is done?
Remayz
jeudi 27 avril 2023, 18:54
Software or virtual sensor = needs the Aquasuite service to be running.
If you want to play purely hardware you will have to connect a temperature sensor to the Octo.
but...
You could easily not care about it if you just do a little test, stress testing the computer and setting a static fan speed, to see how your loop cools the PC with zero control. It often turns out that you can simply leave your fan curves as they are, and only set the fallback % value to a fan speed that's enough to cover your ass no matter what happens.. booting, eventual crash of the service etc..
Just as an example on my rig, a fan fallback speed of 40% PWM is more than enough to cool the PC in all situations. That's what it runs at boot.
If you need to run the PC without windows though, you'll want a sensor hardwired to the octo, and your fan speeds directly controlled by that.
klara
vendredi 28 avril 2023, 07:04
but...
I didn't notice that there is a fallback value under fan curve. It should be enough for me. Thank you for nice tip!
Discussions similaires
