• 01.10.2026, 02:53
jameslim
USB connection issues with OCTO and High flow NEXT after Aquasuite version update.
vendredi 10 novembre 2023, 20:49
After update of Auqasuite version to X.76. There is USB connection issues with OCTO and High flow NEXT.
After turning on the computer, there are several sounds of usb connection and disconnection. And then It shows The device has no USB connection or is not recognized by the system.
In order to fix this, I have to reboot the computer and If I am lucky then there is no problem, if I am not then it keeps happening again and again.
I am using window 11. I have no clue how to fix this.....
Anybody had this issue???
So frustrating....
jameslim a envoyé l’image suivante :
samedi 11 novembre 2023, 10:30
switch off the power supply unit correctly. Unplug the power cable for at least 1 minute.
Uninstall the usb device from you control panel, restart your computer.
jameslim
samedi 11 novembre 2023, 20:13
I already tried that several times.. I never experience this problem before. Is there any way to go back to the previous version?
lundi 13 novembre 2023, 07:23
This has nothing to do with the aquasuite.
Uninstall the USB device in Windows. Settings -> Devices -> Remove
Raymondinio
dimanche 31 décembre 2023, 16:29
I've just had the same problem Win11 after updating to X.77 last night ( could be coincidence ) .
I'm running 1 Octo & 1 Quadro running externally via 2 Usb to male headers to the original cables.
I'm using them to control my temperature in my AV rack initial set up from my HTPC ( so just fans & temp sensors ) .
Not sure if its the cables / hardware or software yet or PC !
Sometimes If I swap the usb cables one will work then change them over & the other will work ?
They come on & disappear randomly sometimes the Aquasuite screen also completly blacks out .
Now they both show no usb connection , tried removing the device's changing ports but still the same problem .
While I'm waiting for new cables Is there anywhere to get the older version just to try ?
Its a shame as I spent 2 weeks making a wiring loom to exact lengths for the 6 sensors & 12 fans I use .
The hardware & software was perfect for the job & was running flawlessly for 18 months till the upgrade.
I'll try removing the devices again as listed here when cables arrive .
