• 17.11.2026, 11:58
theruinedcity
question about the Ultitube 200mm pro
jeudi 28 décembre 2023, 18:31
I picked up the Ulititube 200mm d5 next pro, it came with a usb cable and rgbpx cable. I understand where the usb cable connects to, but does the rgbpx cable connect from the pump to the input on the ring? Will the splitty4 also work with the ultitube as well, I know that the ultitube only have 25 watts. Would that work with the splitty 4, because I can connect my Corsair AF120 Elite fans to it? I wish there were better instructions.
Peter von Frosta
jeudi 28 décembre 2023, 19:04
Yes - and then you can control the LEDs of the Ring via the D5Next Tab in the Aquasuite
theruinedcity
jeudi 28 décembre 2023, 19:16
So technically I could get a rgbpx cable and connect the out on the ring to the splitty 4. Then use my corsair fans with rgb as well. If I connect the splitty 4 to the pump fan controller will I exceed the 25 watts on the pump?
Peter von Frosta
jeudi 28 décembre 2023, 19:32
Yes - the Splitty 4 will work with the D5 Next, but the simultaneous connection of fan-output and (maybe) flow sensor is not possible.
How many Fans do you want to connect to the Splitty 4 and are some of the daisy chained?
If you want to control the LEDs of the Fans you have to take the output of the D5 Next (RGBpx) and connect it to the Splitty 4.
Therefore the LED-Ring has to connect to the outport of the Splitty 4 or from D5 next to the Ring (in) and from the Ring (out) to the Splitty
Peter von Frosta
jeudi 28 décembre 2023, 19:38
It depends of the number of Fans you want to connect to the Splitty 4
One Corsair AF120 Elite has a power draw of 4,56W peak so five Fans@100% should work
Ce message a été modifié 2 fois. Dernière modification effectuée par "Peter von Frosta" (28 décembre 2023, 19:46)
