• 06.11.2026, 11:23
Nioktefe
Delta temp QUADRO
jeudi 20 juin 2019, 18:37
Hello,
Is it possible to create a soft sensor that substract 2 temp sensor value ?
I know that's possible with aquaero but it's way overkill for my build (not to say it's too big for my case)
I would have loved to also be able to configure 2 temp sensor for a fan (max of both or even sum of them (like in speedfan....))
It's a shame because the device is perfect for my needs otherwise, I just hope it's not a market segmentation thing....
jeudi 20 juin 2019, 21:18
Unfortunately, no. Only the aquaero has virtual sensors where one can manipulate multiple sensors to a single value result.
