Du bist nicht angemeldet.
StephanWeber
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »StephanWeber« (4. November 2017, 07:56)
StephanWeber
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »InfoSeeker« (4. November 2017, 17:06)
Dundys
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (4. November 2017, 17:03)
Dundys
O No
I appear to be having an issue with the aquabus.
The High Flow USB sensor does not list under aquaero>sensors tab (a6_sensors_flow.jpg)
The D5 USB pumps also do not list under the aquaero>Pumps tab (a6_pumps.jpg)
And the D5 USB Pumps are not available as a source for a preset controller (pumps_preset.jpg)
Dundys
RESOLVED!
I had not followed Sebastian's instruction:
"When you make changes with aquabus devices you have to power of the pc completly (unplug the power cable)! "
After a full power reset the aquabus is working properly.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Dundys« (4. November 2017, 17:11)
Dundys
Power cycle didn't do anything
darn itYou mean PSU cable
connect each PA3 via USB again, honestly this is
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »Dundys« (4. November 2017, 17:43)
I'm stupid I should have just left thing alone, everything in aquabus is gonePower cycle didn't do anything
I had every device connected via USB at initial setup so how come now everything is gone Helppppppdarn it
You mean PSU cable
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (4. November 2017, 17:48)
Dundys
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Dundys« (4. November 2017, 17:58)
I switched the power off switch on PSU and removed cable as well. NO i didn't update anything other than Aquaeros firmware.
So I'm assuming I have to connect now USB to each device and aquaero and do the firmware update?
When I initially did all that it was about 2 years ago I honestly didn't want to bother anymore with this, Im ether getting to old or just getting brain farts, its getting more difficult and confusing.
Advice PLease?
If you use devices with the aquaero that are only connected via aquabus it is indispensable to connect such devices via USB to perform an update of the firmware, otherwise devices will no longer work with the aquaero or show a strange behavior.
Dundys
Please Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Dundys« (4. November 2017, 18:23)
Its nice when everything is functioning properly. Initially it took me forever to hook everything up but that was while ago I still had the energy fro that, something happen in between that now my energy level is so low I just don't feel like doing whole lot around my system I dont know maybe very busy lifestyle, to busy, but its all going to be OK once is done![]()
So Do I connect now every PA3 and USB flow meter via USB to Aquaero or M/B?
I assume to aquaero and than update the firmware again with PA3 connected ?
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »InfoSeeker« (4. November 2017, 18:33)
Dundys
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Dundys« (4. November 2017, 19:29)
Dundys
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Dundys« (4. November 2017, 23:53)
